New gas tank skid plate... can you say aluminum? - Page 22 - JeepForum.com
post #316 of 927 Old 05-23-2009, 12:14 PM
Humboldt
Humboldt's Avatar
Originally Posted by provelogear View Post
Joe,
Was your rear cross member bent up or just the stock skid? It looks like the stock tank skid is up on the right side. My 2003 looked similar and I had to spend some time with a 3 pounder to get it back in shape. The new mounting bracket was designed so this won't happen again.
Thanks for the pictures the Jeep looks great!
Gerald
The stock skid was bashed in really bad on the pass front and was getting worse since the stock mount on that side was failing. Once those front mounts buckle, it takes that rear crossmember and twists it up. Thath let the whole tank push up a couple inches since the body lift left so much space for it to move up with the stock skid.
True to my nonsavvy self, I didn't think to straighten the rear crossmember until I had the tank and skid in place trying to put the far right nut on the crossmember Fortunately I was able to catch a thread on the bolt and get it tightened. It pulled the crossmember back into shape when I got them all torqued down.
Humboldt is offline
post #317 of 927 Old 05-24-2009, 03:20 PM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
After yesterday's day on the rocks, the new Savvy skidplate held up to some amazing (!!!) hits that were so hard that a few of them hurt. In fact, the skidplate held up far better than my Jeep did. The skidplate earned some pretty serious scratches but nothing that could be considered a gouge or dent, I'm impressed... really! I didn't expect to be able to test it as thoroughly as it was but tested it was on Pumpkin Eater at Hi-Desert Roundup in the SOCAL desert.
So the skidplate held up to the rocks very well but the at the end of Pumpkin Eater (a tough local rock crawling trail), it got a little crazy after taking one last extra optional loop.
After a control arm mounting bolt broke and shifted the rear axle forward, it went downhill from there... the rear driveshaft broke at the yoke, a driveshaft u-joint broke (edit: I just found the D44 pinion yoke was damaged too), a wheel broke, the upper-rear control arm bracket was torn off the axle, a control arm mounting bolt broke, the ignition coil gave up, and I'm beat. Not to mention the huge Chuckwalla lizard a dog chased under my Jeep that ran up me and over my face while I was laying underneath working on the Jeep. My back is toast from laying on the rocks 90 minutes repairing what I could on the trail, at least I had a lot of help from some really great guys (Desert Dawgs 4x4 club) on the run and I'm thankful one of them had a welder for the torn control arm mount. Another (Desert Dawg and JF member Joe Smith) had a spare driveshaft he generously loaned me. I lost track but the carnage in our group that day wasn't confined to me... we had a couple broken axle shafts, broken Warn hub, broken axle tube, another broken control arm mount, and a few others. At least the Savvy skidplate came through with nary a wimper. I think I'll go take a nap now.
Edit 6/4/09 by JB: I just received a new replacement rear driveshaft together with a new t-case output shaft yoke and Dana 44 yoke from driveshaft guru Tom Wood. It's been a long time since I've had a new driveshaft and I have to say, a Tom Wood driveshaft is a work of art. I'll be installing it this coming weekend.
Jerry Bransford is online now
post #318 of 927 Old 05-24-2009, 06:28 PM
Pvt_Joker
Originally Posted by Jerry Bransford View Post
My back is toast from laying on the rocks underneath the Jeep 90 minutes repairing what I could on the trail, at least I had a lot of help from some really great guys on the run. I lost track but the carnage in the group wasn't confined to me... we had a couple broken axle shafts, broken Warn hub, broken axle tube, another broken control arm mount, and a few others. At least the Savvy skidplate came through with nary a wimper. But I think I'll go take a nap now.
this made my wallet hurt
Pvt_Joker is offline
post #319 of 927 Old 05-24-2009, 10:40 PM
lukethedork
Don't mean to offend you guys or anything. But after looking at both the pictures from Humboltd and Jerry, those scrapes or 'gouges' look fairly sever for being only the first or second trip out with them. I wouldn't like to see how much metal has been removed after a year or two of hard wheeling!
Although it is hard too tell depth from a picture. After seeing those gouges I will be going with a steel gas tank skid myself.
Luke.
lukethedork is offline
post #320 of 927 Old 05-24-2009, 11:44 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Luke.
No offense taken at all. But, perhaps if you had a better understanding of the terrain these guys are playing in, you might develop a different opinion.
That stuff out there is just harsh, mean, and unforgiving. This is what a steady diet of it does to a Jeep.
Clamp from Currie steering-
Bolts and steering box skid-
Shock stud and nut-
Control arm bracket- notice the burrs peeled up that will slice you open like a razor.
Another-
Notice the depth of the gouges in steel-
Look at the scratches on the driveshaft-
And finally, the skid that's been under my rig in the same terrain for a longer period of time and it's the same material as the Savvy Gas Tank Skid.
Yep, it scratches, it gouges, but it's never once got me stuck, nor has it dented or failed.
All of which is fairly moot because if you tear it up, we'll take care of it at no cost to you.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #321 of 927 Old 05-24-2009, 11:49 PM
Douglas S.
Damn, my jeep wouldn't last a minute out there.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #322 of 927 Old 05-24-2009, 11:49 PM
Goobersbro
So when are you guys going to start making these for the Yj's
Sorry if you already covered this I have peeked in here from time to time waiting to see some pictures of it installed on Jerry's rig
My marshmallow build
Goobersbro is offline
post #323 of 927 Old 05-24-2009, 11:58 PM
Dukes69
Dukes69's Avatar
Luke.
Well, when you "wear it out" they'll send you a new one. Good luck finding another skid company that will do that.
On another note, we just got back from "testing" the skid. I ending up peeling back the rear diff cover taking some stupid lines to hit the skid. I, otherwise, was unable to hit it. So if you can't hit the thing, how can you cry about it not holding up? I'm sure the pics will hit the interwebz soon.
AIM: Dukes69
Ya Savvy?
Dukes69 is offline
post #324 of 927 Old 05-25-2009, 12:07 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
After yesterday's day on the rocks, the Savvy skidplate held up to some amazing (!!!) hits that were so hard that a few of them hurt. In fact, the skidplate held up far better than the TJ did. The skidplate earned some pretty serious scratches but nothing that could be considered a gouge or dent, I'm impressed... really! I didn't expect to be able to test it as thoroughly as it was but tested it was on Pumpkin Eater at Hi-Desert Roundup in the SOCAL desert.
So the skidplate held up to the rocks perfectly but the at the end of Pumpkin Eater, my LR wheel cracked so it won't hold air, the rear driveshaft yoke and u-joint broke, the upper-rear control arm bracket was torn off the axle, a control arm mounting bolt broke, the ignition coil gave up, and I'm beat. My back is toast from laying on the rocks underneath the Jeep 90 minutes repairing what I could on the trail, at least I had a lot of help from some really great guys on the run. I lost track but the carnage in the group wasn't confined to me... we had a couple broken axle shafts, broken Warn hub, broken axle tube, another broken control arm mount, and a few others. At least the Savvy skidplate came through with nary a wimper. But I think I'll go take a nap now.
Jerry,
Looks like a real fun day! Is that all you could do to that skid?
We didn't fare any better. We purposely went out today to destroy a skid and were completely disppointed! All we could get is minor sratches. Two Jeeps (Chris/Tammy and Nik Vallens) had new skids on and they were dropping of ledges and backing into rocks with reckless abandon. I thought for sure we would get a couple of dents but only a little metal gets sanded off. I finally got a picture of a small bend on the trailing edge after Chris backed into a pointy rock three times!
Thanks for posting up the pix. I'll get mine up in the morning. Like you it's been a long day.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #325 of 927 Old 05-25-2009, 12:08 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
That area is precisely why we do what we do. If a product will survive out there, I have no worries about it surviving anywhere else.
We try to explain to folks just how mean the rocks are, but until you see the pics and what we put our rigs through, it's difficult to understand.
Those pics of the white rig, I didn't take pictures of all the wear and tear, just the more spectacular stuff.
I am Savvy
post #326 of 927 Old 05-25-2009, 01:44 AM
snellav
snellav's Avatar
It's also important to keep in mind that aluminum wont rust like steel. When you bash up steel and fail to repaint or refinish it, it will start to rust. Over time, that rust can diminish the strength of the skid.
I also know some people have had the problem of their steel gas tanks rusting from the inside out, as water can become trapped between the skid and gas tank.
The pics above show how dirty and rusty steel parts can become. In comparison, the aluminum belly skid is still "clean" and deposit free.
98 2 Door Cherokee SE 4x4 - Stock
00 TJ w/ D60s and lotsa other stuff - Gone but not forgotten
snellav is offline
post #327 of 927 Old 05-25-2009, 08:57 AM
robncar
robncar's Avatar
Aw, that'll buff right out...
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #328 of 927 Old 05-25-2009, 09:17 AM
SuperWade2
More Money than Brains
SuperWade2's Avatar
I little duct tape would hold that crack just fine...
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #329 of 927 Old 05-25-2009, 09:29 AM
06WranglerX
Shock stud and nut-
Another-
Wow i would really love to "try" and play out in those areas with you guys. I have looked over the pics from the Hammer trails and wow craziness. If the skids can survive out there with what those guys are doing, anyone else should have no real worries, it really is a night and day difference in wheeling. Only wish i could get my jeep out there and try some of the lower trails in JV!
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline
post #330 of 927 Old 05-25-2009, 09:34 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
That's all done on the "lower" trails out there.
But, if you ever want to come out, let us know. Thanksgiving is especially good.
I am Savvy
? about gas tank/skid plate Jeepfan Jeff YJ Wrangler Technical Forum 7 01-03-2010 02:15 PM
Aluminum transfer case skid plate Wheelin98TJ TJ Wrangler Technical Forum 12 11-20-2009 09:55 AM
Savvy offroad aluminum gas tank skid plate mustgooverit TJ Wrangler Technical Forum 0 08-26-2009 11:48 PM
Gas tank skid plate Lee3333 YJ Wrangler Technical Forum 7 06-13-2008 06:32 PM
Gas tank skid plate help J13760 YJ Wrangler Technical Forum 1 04-13-2006 11:55 AM
