New gas tank skid plate... can you say aluminum? - Page 10 - JeepForum.com
post #136 of 927 Old 05-11-2009, 07:56 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by Flipside View Post
Yes, I too am disappointed that the Medic is no longer... Perhaps the Savvy group will come up with a replacement for the shovel on my 06 LJ? Even better would be a design that doesn't require a BL to work its magic!
Just a few words on the manufacturing end of things. It's not wise from a business standpoint to make 17 different versions of the same product.
It's not wise to make the same product and have two different versions with and without a body lift installed.
The pre03 is easy from that standpoint, so when we get that product in the development queue, the chances of it working without a body lift are relatively slim.
That's likely going to be due to our "highest level of performance possible" for the dollar spent philosophy. We fully intend to have our products abused mercilessly and for the customer to smile the whole time they're doing it.
mrblaine: what say you on the issue of galvanic corrosion with your Aluminum bling?
I say it's a non issue and will be one until the day comes when your aluminum cased copper wound alternator eats up the steel bolts holding it to an iron block with electricity present.
Or, it will be a problem when your aluminum intake that's bolted to stainless steel and iron exhaust with steel bolts that's full of brass and zinc plated sensors, starts to have an issue. Until then, I'm going to pretend you never brought this up.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #137 of 927 Old 05-11-2009, 08:00 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by chefdab View Post
I have two questions about this skid.
1.) It was stated that it mounted to the rear cross member to keep it farther away from the track bar. Is that still the case for an Unlimited or does it mount in the stock location which leaves open space between the gas tank and rear cross member?
Sorry, it should be worded that it's connected back to stock rear crossmember that it originally bolts to.
2.) Correct me if I'm wrong, but is there any risk of electrolysis using disimilar metals for the mounting than the skid itself?
Already answered, but if you manage to encounter enough electrolysis to damage the skid, we'll take care of it.
I am Savvy
mrblaine is offline
post #138 of 927 Old 05-11-2009, 08:05 PM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That part of my writeup was corrected earlier today, the original wording was bad and misleading.
Jerry Bransford is offline
post #139 of 927 Old 05-11-2009, 08:33 PM
red rubi
So long pal!
red rubi's Avatar
So, does everybody in Cali have carpeted garages and driveways?
red rubi is offline
post #140 of 927 Old 05-11-2009, 08:36 PM Thread Starter
Jerry Bransford
Administrator
You know what carpeting is good for in the garage? To soak up spilled lubricants and form ugly stains, and nearly catch on fire/smolder/smoke in multiple locations from flying welding sparks. Ask me how I know this
post #141 of 927 Old 05-11-2009, 08:43 PM
red rubi
So long pal!
red rubi's Avatar
Looks good on paper, but looses it in execution.
red rubi is offline
post #142 of 927 Old 05-11-2009, 09:04 PM
brunosplace
Tested this theory a few times, have you???
Originally Posted by Boodyrider View Post
Big tires, done right, are FREAKING EXPENSIVE. Deal with it, or don't go there.
Originally Posted by woodnjeep View Post
I live in the land where they salt cure roadkill.
97 Jeep TJ Sport, 4.0L, Auto, 3" BDS Lift (SOLD)
98 Jeep ZJ Laredo 4.0L, Auto, Stock
, parted out and scrapped
96 Jeep XJ Sport, parted out and scrapped
brunosplace is offline
post #143 of 927 Old 05-11-2009, 10:00 PM
Flipside
Flipside's Avatar
I couldn't agree more, especially since you're in a niche market segment. You've probably already thought about this, but if everyone else's tummy tucker / tranny skid / engine + oilpan skid requires a lift and yours doesn't, you've opened up your market considerably.
Further, in terms of preserving a low CG, why go through the conversion of gaining [for sake of arguement, we'll call it] 2" of break over clearance by replacing the factory skid, if you need to lift the body and or add a MML to accomodate the new skid?
All things considered, I'd pay a premium to keep the CG low AND gain the clearance. After all, what do all the lifts cost to do things 'the other way?'
Do something by yourself and it's called wierd. Do it with others and it's called a club.
Flipside is offline
post #144 of 927 Old 05-11-2009, 10:30 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
At the undesireable risk of turning this into a low COG discussion, I've built enough rigs that go very difficult places to pretty much dismiss most LOW COG discussions as pretty much hogwash.
But, if I were to consider the COG parameters everyone is so hyped up about, I would first point out that a 1" lift of the motor and body to gain 3" of belly clearance is a sound trade. That's the equivalent of putting on 6" larger diameter tires where you need it most.
LOW COG's require you to bumpstop and limit uptravel and there is simply no free ride. If you run a 12" shock with 3" of uptravel, all you wind up doing is lifting the whole jeep up which then requires you to have more down travel to reach the ground as a rig set up 6 and 6 whose body won't go up as high on the same rock.
If you're willing to pay a premium, I'd start by channelling the body and cutting out the trans tunnel. The bottom line is there is X amount of distance between the top of the trans and the bottom of the tub. If you want more belly clearance, you have to raise the trans. If you raise the trans, you can only go so far before you have to raise the tub and that's even with severe dimpling.
I am Savvy
mrblaine is offline
post #145 of 927 Old 05-11-2009, 10:37 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by fromme View Post
It's just about one inch, maybe slightly less. The bar crosses right over the middle of the clips that hold the hard plastic lines on the driver's side on my 04. And there is absolutely no more room between those plastic lines and the A/R bar. The are rubbing as is, I had to sleeve those lines.
Relevant or not so relevant, but once upon a time I removed the lines out of those clips and the clips and mounted the lines right behind the crossmember to the bottom of the tub where there was more room for them. That was to shove an A/R bar through over the top of a raised tank. Might see if that makes sense for what you're trying to accomplish.
I am Savvy
mrblaine is offline
post #146 of 927 Old 05-11-2009, 11:41 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by mudb8 View Post
any questions?... lets start a new thread or e-mail me
Nope, no questions.
I am Savvy
mrblaine is offline
post #147 of 927 Old 05-11-2009, 11:46 PM
mudb8
want it rite or rite now?
mudb8's Avatar
Nope, no questions.
lol, mrblaine that wasn't directed at you... sorry if it seemed so just used your statement..
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #148 of 927 Old 05-12-2009, 12:07 AM
Alexia
Alexia's Avatar
I am looking into gas tank skids since I will be dropping my gas tank within the next month to work on a few things. I would prefer to only have to do it once!
All of the skid plates I have looked at are unfinished, but since this is aluminum that should be fine. Can it be powder coated safely with adverse effects to the metal? Otherwise I would leave it bare.
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Alexia is offline
post #149 of 927 Old 05-12-2009, 12:16 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Yes, it can be powdercoated with no issues. Or, you can paint it as long as there is a chem film done as a base similar to Alodine.
We will shortly have an option for those in high corrosion environments to order the skid base with the chem film already done to it in preparation for paint or powder. We found a local processor that can do a chem film in clear that doesn't change the color of the aluminum.
I am Savvy
mrblaine is offline
post #150 of 927 Old 05-12-2009, 02:05 AM
lukethedork
I might sound stupid, but I don't know what a 'chem film' is...
If I buy a can of spray paint from the local store. Can I use this to paint the skid or will it be bad for it?
Luke.
lukethedork is offline
? about gas tank/skid plate Jeepfan Jeff YJ Wrangler Technical Forum 7 01-03-2010 03:15 PM
Aluminum transfer case skid plate Wheelin98TJ TJ Wrangler Technical Forum 12 11-20-2009 10:55 AM
Savvy offroad aluminum gas tank skid plate mustgooverit TJ Wrangler Technical Forum 0 08-27-2009 12:48 AM
Gas tank skid plate Lee3333 YJ Wrangler Technical Forum 7 06-13-2008 07:32 PM
Gas tank skid plate help J13760 YJ Wrangler Technical Forum 1 04-13-2006 12:55 PM
