New fuel pump or what - Page 2 - JeepForum.com
post #16 of 17 Old 07-24-2010, 08:02 PM Thread Starter
turkeybuzzard
Thanks to all, I have the 19 gallon tank. Was able to see a detailed picture of the 15 and 19 gallon pumps.
turkeybuzzard is offline
post #17 of 17 Old 07-25-2010, 02:44 AM
Jonny Jeep
Jonny Jeep's Avatar
Originally Posted by cntryboy97 View Post
how difficult is the regulator replacement (the one shown on the ebay link)? I also have the long crank problem and I wonder if I should replace the fuel pump & the regulator. Thanks
Once you have the tank down it's easy. Remove the fuel line. Pry off the clip that holds the filter/regulator in place. Pull the thing straight up to remove it. I only replaced the filter/regulator on my TJ. I'll do the pump only when it fails.
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline
anti-drainback valve , fuel pressure regulator , check valve
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 04:42 PM
inline fuel pump or new tank with pump in it? cubbybear YJ Wrangler Technical Forum 2 12-25-2008 05:13 PM
Fuel pump assembly vs. fuel pump? eclipse27 TJ Wrangler Technical Forum 11 11-11-2008 09:18 AM
Electric Fuel Pump Issue, NOT pump 1995yj1978cj YJ Wrangler Technical Forum 4 05-28-2005 12:12 PM
