New Front Bumper Suggestions- Towing - JeepForum.com
post #1 of 4 Old 08-31-2008, 08:51 AM Thread Starter
luk4mud
Ok, the front bumper got kinda messed up on the Dusy this summer, so upgrade opportunity is upon me. Lots of nice bumpers out there, but I have one overriding concern- I tow my TJ behind my camper so I need to be able to mount a simple A-frame towbar to the new bumper.
Does anyone make a bumper that allows the towbar to mount directly to perhaps the clevis mounts it without welding or bolting on those A- frame mounts.
Thanks in advance for any and all help.
Originally Posted by Divinitous
I did something like this a while back for my corolla. I poked a hole into the ducting and ran a hose to stick into my shorts. It didnt work thew best cause I never plugged up the vents, but it did help.
luk4mud is offline
post #2 of 4 Old 08-31-2008, 09:00 AM
default_user
It's a Roobicon
I have the Body Armor bumper that might work
And they sell tow bar brackets here http://www.truckaddons.com/Catalog/s...eepbumpers.htm
default_user is offline
post #3 of 4 Old 08-31-2008, 09:17 AM
durango-bob
2006 WK
Any front bumper with clevis mounting tabs and no protruding parts between them can be made to easily work. I have an ARB bumper and connect to the clevis mounts. An inexpensive Reese type colapsable tow bar is all that you need besides the connecting hardware. Click on the pic to see how I made mine work. Basically, the outer diameter of the tow bar end brackets slide into the clevis mount. A pipe that is sized to fit between the brackets is held in place and then a rod is inserted through one end and out the other. A simple spring clip holds the rod in place.
durango-bob is offline
post #4 of 4 Old 08-31-2008, 09:25 AM
bairy
this is what I did. You can do this to almost any bumper with clevis mounts...
I used a $50 Pitbull towbar and bent up some 1/4" plate. Use a good safety chain and you are good to go.(I did not use that whimpy chain that came with the tow bar)
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
suggestions on a front bumper akread TJ Wrangler Technical Forum 40 01-14-2010 04:46 PM
2002 tj, needs a new front bumper. SUGGESTIONS PLZ canadianTJ TJ Wrangler Technical Forum 16 01-05-2010 03:53 PM
Need Suggestions To Reattach My Front Bumper rastaangel TJ Wrangler Technical Forum 2 04-30-2009 01:39 PM
Hood & Front Bumper Suggestions HafellaFUSE JK Wrangler Technical Forum 4 05-27-2008 04:27 PM
Front bumper suggestions jayr TJ Wrangler Technical Forum 3 09-19-2006 12:23 PM
