New to forum. Tow Bar Help - JeepForum.com
post #1 of 7 Old 07-27-2010, 02:37 PM Thread Starter
MisterMcD
I am brand new to this forum and actually a brand new jeep owner. I bought a totally original 1998 Wrangler Sahara from the original owner. I already did some maintenance things to it. New brake job, new passenger side rear axel (owner disclosed that it was leaking oil so when the shop checked it out, they said it had worn a groove in it so I had it replaced) I also got new link pins and a serpentine belt) The shop where I took it said that was all i needed besides a coolant flush.
Anyways, I want to put on new tires without a lift and get a tow bar to put on the front of it so I can tow it behind my motorhome.
1. In Metric measurments, what is the largest tire I can put on it without a lift or adding washers?
2. What kind of tow bar should I get? The Blue Ox type are really expensive and the UHaul one I looked at today doesn't appear to be able to bolt on to the frame easily. I don't really have anyone who can fabricate a piece to weld on so I want to do something that is kind of meant for my vehicle. Anyone have an suggestions? What about a place to buy used base plates and arms?
Thank you very much for your help!
MisterMcD is offline
post #2 of 7 Old 07-27-2010, 02:49 PM
bairy
Here is some info for a bolt on tow bar:
Currie Enterprises CJ Axle Parts
Welcome!
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #3 of 7 Old 07-27-2010, 03:19 PM
jonrjen
2011 KK Liberty
Take a look here. Another like post.
http://www.jeepforum.com/forum/f27/tow-bar-1077158/
"If you have a difficult job to do....Give it to a lazy man....He'll find the easy way to do it."
jonrjen is offline
post #4 of 7 Old 07-27-2010, 06:32 PM
wushaw
Rockin jeep
wushaw's Avatar
The Blue Ox & Roadmaster tow bars maybe expensive but after you buy one that's extendable you will never go back to a solid tow bar, the solid ones are just difficult to hook up.
wushaw is offline
post #5 of 7 Old 07-27-2010, 07:51 PM
jonrjen
2011 KK Liberty
True the extending arms and self locking features are nice to have. However I have found that on a Wrangler the solid arms are not that difficult to deal with. The Wrangler itself is light enough that you can move it my hand on level ground.
It is also a lot like backing up to hook up to a trailer, only you are going forward. Once you get the hang of it, It is no big deal.
If the budget is limited the basic tow bar will get the job done with money to spare.
jonrjen is offline
post #6 of 7 Old 07-27-2010, 08:13 PM
wushaw
Rockin jeep
wushaw's Avatar
I started out with a solid tow bar and after 4 years I upgraded to a user friendly one, I can hook up in under a minute, I could never do that with the previous tow bar.
I know exactly what it took to hook up and level ground is premium.
wushaw is offline
post #7 of 7 Old 07-27-2010, 08:43 PM
jonrjen
2011 KK Liberty
Level ground is premium with the hooking up any tow bar.
One of the nicest features I had found with the Roadmaster Blackhawk that I used to tow my F-250 was the ability to leave the tow bar connected and folded up on the back of the motor home. Where as you do need to remove the less expensive tow bar and store it somewhere until it is needed again. And the self centering and auto lock does make for a quick simple experiance. I don't disagree with how nice the high dollar units are to use.
However the original poster expressed that he was looking for a less expensive towing solution than the Roadmaster or Blue OX systems.
So if it is a matter of budget vs. convience....you can still buy the complete Currie tow bar and mounting bracket for less than just the vehicle mounting brackets needed for the Roadmaster or Blue OX units. And then it is another $500 for the tow bar itself.
Let's just hope the OP doesn't what to get into a discussion of Toad/Dinghy brakes. I like the Ready Brake set up for price and it's simple mechanics...however I have a Brake Buddy because the price was better than right.
jonrjen is offline
tow , tow bar
Goodbye YJ forum Hello TJ Forum! figbush1 TJ Wrangler Technical Forum 11 12-27-2010 12:55 AM
New to Forum BigMark JK Wrangler Technical Forum 4 05-13-2007 08:59 PM
Goodbye YJ Forum Hello TJ Forum ;) figbush1 YJ Wrangler Technical Forum 0 10-18-2006 03:06 AM
New to the forum. Swedejeeper TJ Wrangler Technical Forum 5 03-20-2005 10:02 PM
New to the forum GotLift YJ Wrangler Technical Forum 8 03-04-2005 06:46 AM
