New centering ball in Front drive shaft...still angry sparrows! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > New centering ball in Front drive shaft...still angry sparrows!
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 03-02-2012, 06:45 AM   #1
chupathingy901
A few weeks ago, i got the common "angry sparrows" front drive shaft issue. I pulled it off and the noise went away. I took the shaft to a shop and got the centering ball and u-joints replaced. (only charged $65!) One week later, the angry sparrows are back. However, its only above 15 mph and only happens sometimes. The noise doesnt seem to change with the speed either..but it definately sounds like the d*** sparrows again. Any suggestions? The jeep's frame and body mounts rusted away, so I need to part it out... (depressing...only had it 6 months) but ill be driving it for a few more months so id love to kill these birds.
chupathingy901 is offline   Reply With Quote
Unread 03-02-2012, 06:53 AM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
For $65, I doubt the shop did the work you say they did.
(3) u-joints alone is close to $65.
They probably left the centeing ball alone and just greased it as well as they could.
Wheelin98TJ is offline   Reply With Quote
Unread 03-02-2012, 06:55 AM   #3
chupathingy901
I forgot to mention I provided the u-joints hahaha i gave them to them to pu them in, i inspected the shaft too, they really did replace the ball and put my Duralast u-joints in for me
Unread 03-02-2012, 07:17 AM   #4
Imped
Imped's Avatar
Did you replace just the ball or the whole socket assembly? What brand?
And duralast joints? Really man?
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 03-02-2012, 07:23 AM   #5
bobjp
Axle u-joints make the same noise, so I would check those next. Also, when (not if) those Duralast joints fail, buy some other brand. I know they have a lifetime warranty, but I'd rather pay more and not have to replace them every year.
97 TJ sport.
bobjp is offline   Reply With Quote
Unread 03-02-2012, 07:34 AM   #6
chupathingy901
the socket too, and I work at AutoZone, that's why I just grabbed some from work
Unread 03-02-2012, 07:36 AM   #7
chupathingy901
Yeah I work at Autozone that's why I got those. Ill check those axle joints though thanks!
Unread 03-02-2012, 09:27 AM   #8
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Did they forget to grease the CV's centering joint?
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 03-02-2012, 10:39 AM   #9
GrantLasson
On my new driveshaft, a greaseable Spicer centering joint added $100 to the total cost. Not sure what you got for $60 (including labor).
The expense of a failure so far exceeds the money spent on the centering ball that it doesn't make sense to take risks.
GrantLasson is offline   Reply With Quote
Unread 03-02-2012, 03:04 PM   #10
chupathingy901
Went wheeling today and it went away, lets see if it stays that way haha
Unread 03-02-2012, 03:11 PM   #11
IH8ROADZ
Always use spicer for the driveshafts.
IH8ROADZ is offline   Reply With Quote
Unread 03-02-2012, 10:22 PM   #12
ops5
ops5's Avatar
You better be sure, I would check if it is greased. I hate to see you blow your transfer case in half
ops5 is offline   Reply With Quote
Unread 03-02-2012, 11:55 PM   #13
ClimbStuff
I replaced everything when it happend to me in 2010, and it went away immediately. I used good U joints though... it was whatever the best kind I could get form AdvanceAuto at the time... I remember the seals and grease being red if that means anything to anyone.
ClimbStuff is offline   Reply With Quote
Unread 03-03-2012, 12:50 AM   #14
BUSA
What all should be replaced when doing my front and rear u-jointz. Should i replace the centern ball too? THANKZ JEEPERZ
BUSA is offline   Reply With Quote
Unread 03-13-2012, 08:12 PM   #15
chupathingy901
My Centering ball is still squeeking like crazy over 20 MPH, I called the shop and they said "I'm not sure we have a greasable centering ball for that..bring it down." But I might just buy the front shaft of a guy parting out a Jeep near me for $60, i mean, might as well. Probably will be cheaper...
