New axle - steering wobble - JeepForum.com
post #1 of 14 Old 08-16-2017, 10:27 PM Thread Starter
MDTJ
MDTJ's Avatar
I have a wobble in the steering wheel with the new HPd30 I installed. Around 35-40 the steering wheel wobbles unnervingly, but it isn't death wobble. My previous LPd30 didn't have this, it is new. I also didn't notice it when I had 600-800 lbs of gear in the Jeep last week.
Rebuilt axle. New ball joints. New CA bushings at the axle. New track bar. Shop aligned it after I installed. Shop rebalanced the tires.
Here's my guess, but what else should I consider? Since I didn't notice it with the weight in the Jeep my guess is it could be related to caster angle. More weight increased the caster. That's all I got, what you got?
Good resources:
MDTJ is offline
post #2 of 14 Old 08-16-2017, 11:17 PM
Erocket
Most likely is driveshaft angle, maybe the shop pointed pinion down too far to get caster higher and u joint is creating the vibration. Or just that its a high pinion axle the u joint is not at the angle it previously was. Did you install a new u joint and check the angle on it?
Sent from my LG-H872 using Tapatalk
Erocket is offline
post #3 of 14 Old 08-16-2017, 11:36 PM
Shark_13
Did they crank up the air pressure in the tires after the balance? Check easy things first
Shark_13 is offline
post #4 of 14 Old 08-17-2017, 12:44 AM
biffgnar
biffgnar's Avatar
Driveshaft vibes and steering wobble are two different things.
biffgnar is online now
post #5 of 14 Old 08-17-2017, 05:03 AM
Loukaps
Loukaps's Avatar
why the track bar drop? check to make sure all of that is torqued to spec.
Loukaps is offline
post #6 of 14 Old 08-17-2017, 09:12 AM
TJnBC
Go back to the shop who did all the work.
Get them to check the balance of all tires and the alignment specs (Toe in, caster etc) Try a simple tire swap, front to back and try to duplicate it. Might be a process of elimination.
2006 LJR...the madness begins again
TJnBC is offline
post #7 of 14 Old 08-17-2017, 03:58 PM Thread Starter
MDTJ
MDTJ's Avatar
Ok, too many to quote here so I'll just respond in bulk. Thanks for the help.
  • Tire pressure has been checked and adjusted. I should have mentioned that in the first post.
  • There isn't a track bar drop. Not sure why that came up, Loukaps
  • I did all the work, not a shop.
  • This isn't vibes. It is a speed related steering wobble.
Good resources:
MDTJ is offline
post #8 of 14 Old 08-17-2017, 04:29 PM
Erocket
Ok. Knuckles, bearings, axle shafts all new? Swapped over from old axle or?
Erocket is offline
post #9 of 14 Old 08-17-2017, 04:47 PM
TJnBC
I am pretty sure you have a tire balance issue. Otherwise you would feel this wobble at more than one speed
TJnBC is offline
post #10 of 14 Old 08-17-2017, 06:17 PM
aeroshots
Caster angle would be my guess too. Did shop only adjust toe?
aeroshots is offline
post #11 of 14 Old 08-17-2017, 10:23 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Knuckelhead is offline
post #12 of 14 Old 08-17-2017, 10:39 PM Thread Starter
MDTJ
MDTJ's Avatar
Originally Posted by Knuckelhead View Post
I did all the work. Except the alignment and balance at the end as noted in the top post. For some reason people keep asking/suggesting something about the shop, but there isn't one. \_(ツ)_/
Good resources:
MDTJ is offline
post #13 of 14 Old 08-17-2017, 11:25 PM
TJnBC
Go check your balance again on the tires or rotate them and see if problem persists.
TJnBC is offline
post #14 of 14 Old 08-19-2017, 09:25 AM
aeroshots
The shop I was referring to is the alignment shop. They may have some input into the problem.
