Nerf bar install tricks? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Nerf bar install tricks?
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Closed Thread
Unread 09-18-2002, 09:17 PM   #1
Steveqvs
I installed a couple of nerf bar steps last weekend and the one side has a little creak in it. Went out tonight and tried to readjust the front bracket and that might have helped. Are there any tricks to this? The rear hooked on to a body mount the front uses 2 screws into the \_ part of the floor wheel well. There was no drilling involved.
thanks
Steve
2002 Wrangler X
Solar Yellow
Softop Deep Tint Windows
Mostly Stock
Garage Remote Mod
YJM #4
Steveqvs is offline
Unread 09-18-2002, 09:44 PM   #2
igofshn
Locked @ both ends
igofshn's Avatar
Don't expect them to be very strong. If you rub something they will be torn right off. I have some that are welded to the frame. I've tested mine numerous times. Very strong.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
[Jeep Pics
igofshn is offline
Unread 09-21-2002, 12:08 AM   #3
JPMan-TJ
Deleted all non-thread topic posts. Enough is enough.
~CLOSED~
[b]JPMan-TJ[/b]
JPMan-TJ is offline
Closed Thread
