Need Vacuum Leak Help - JeepForum.com
post #1 of 2 Old 08-25-2011, 07:49 AM Thread Starter
CodyRay
I have a vacuum leak in my 2004 Rubicon that I cannot find at all. It is getting worse and worse. I'm assuming its a vacuum leak because nothing else matches the description. Is there a common place that I am not aware of for this to happen? It only has 62k miles on it. Note: It only does it after it warms up a little.
CodyRay is offline
post #2 of 2 Old 08-25-2011, 03:31 PM
lope
lope's Avatar
You can check for vacuum leak by spraying carb cleaner on different places while your engine is running. Especially intake and vacuum lines and listen for a change in engine idle. If idle changes when you spray, you've found the area of leak so you can inspect closer 'til you find the exact leak.
lope is offline
leak , vacuum
Vacuum leak, now fuel leak? jgillespie YJ Wrangler Technical Forum 4 01-25-2010 10:16 AM
vacuum leak sandman'sjeep YJ Wrangler Technical Forum 5 08-29-2007 10:25 AM
Vacuum leak? COSourdough YJ Wrangler Technical Forum 9 01-25-2006 02:18 PM
'92 YJ 4x4 vacuum leak. _bnkr612 YJ Wrangler Technical Forum 7 06-23-2004 04:01 PM
Vacuum Leak crushnik TJ Wrangler Technical Forum 3 03-25-2003 09:17 AM
