Quantcast Need to undercoat. What to use - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Need to undercoat. What to use
Old 08-15-2008, 07:32 PM   #1
Snowdawg
When I bought my 06 I was living up in northern B.C. The previous owner failed to have the truck undercoated when he bought it. Now that I have moved south in to Vancouver I need to get this done before they start salting the roads for winter.
Any recommendations on what to use and what to watch for here?
Chrome won't get you home, Unless it's Chromoly
Snowdawg is offline   Reply With Quote
Old 08-15-2008, 07:54 PM   #2
Skeezer
Use POR-15. There's nothing better. www.Por-Outlet.com
2006 TJ Sport
1995 YJ
2007 JK Sahara Unlimited
www.GrassRootsJeepClub.com
www.GrassRootsJeepClub.proboards80.com
Skeezer is offline   Reply With Quote
Old 08-17-2008, 11:55 AM   #3
jeepjay90
x2 on por-15, then herculine it if you want
jeepjay90 is offline   Reply With Quote
Old 11-02-2008, 06:26 AM   #4
nujeepguy
1997 XJ Cherokee
fluid film
nujeepguy is offline   Reply With Quote
Old 09-13-2009, 07:27 PM   #5
RockJeepTJ
RockJeepTJ's Avatar
I used POR15 under, POR15 in tub with Grizzly Grip over top and then literally filled my frame and doors with Fluid Film. All three products .......... EXCELLENT stuff !!!
"Compassion and tact are honorable traits, but are not often found in the bad-guys coming through the wire."
Sgt Rock- Former Sergeant of Marines
MY BUILD THREAD:
http://www.jeepforum.com/forum/f22/rocks-2000-tj-rockjeeptj-892796/
RockJeepTJ is offline   Reply With Quote
Old 09-13-2009, 08:10 PM   #6
99TJSahara
4Wheelin' dreamin
99TJSahara's Avatar
Rustoleum primer, then Rustoleum Protective enamel
-Joey
99 Wrangler Sport
04 Grand Cherokee Overland
99 Wrangler Sahara-sold
99TJSahara is offline   Reply With Quote
Old 09-13-2009, 08:13 PM   #7
jmasin
How has the Grizzly Grip held up for you?
'03 Sport, Patriot Blue
'04 C5 Corvette
jmasin is offline   Reply With Quote
Old 09-13-2009, 08:20 PM   #8
mudking_ky87
duplicolor rubberized undercoating it good stuff, I used it on my last jeep, and it looked good and the rubberized coating made it hold and seal good, and its about $4 a can, looks like a spray paint can, just wear old clothes and gloves, it is rubber aerosol, will take about 5 cans to do a good coating.
97' TJ Sport 2.5" - 3" suspension Rancho? lift, 3" BL, Smittybuilt SRC Rear bumper, KC lighing, Tube front bumper and side steps, warn x8000i winch, 33" Mickey Thompson MTZ, magnaflow exhaust, gibson Hi flow cat. more to come in the future!
mudking_ky87 is offline   Reply With Quote
Old 09-13-2009, 08:22 PM   #9
RockJeepTJ
RockJeepTJ's Avatar
The Grizzly Grip has been on since May. It was outside, no top in the Mojave Desert (doesn't get hotter/dryer) for a few months and now we're in Guam (doesn't get hotter/humidy). I am MASSIVELY pleased with Grizzly Grip ...... performance, price, application and customer service.
MY BUILD THREAD:
Old 09-13-2009, 08:35 PM   #10
JDON
So you seriously filled your whole frame with fluid film? how did you go about doing this and how did it turn out, this is my first time ever hearing about this stuff but I am very interested.
JDON is offline   Reply With Quote
Old 09-14-2009, 06:08 AM   #11
Junky burp
Yearly treatments of Krown with a good topping of Fluid Film for the underside. I put the Fluid Film on with a schutz gun... it's practically a grease. Anyone from atlantic Canada can tell you it works.
Junky burp is offline   Reply With Quote
Old 09-14-2009, 07:01 AM   #12
LocknRoll
Fluid Film...yup, good stuff, have used it in the past with good results.
Prolab Tecnolub has a similar product as well (Annual Rustproof treatment #2).
Both are designed to "penetrates cracks, stop existing oxidation and leave a protective rustproofing film".
03 5 spd Black TJ Rubicon, Stock for now
LocknRoll is offline   Reply With Quote
Old 09-14-2009, 07:32 AM   #13
TJoshX
The owner of the major Offroad Outfitter and Line-X dealer up here in Maine refuses to undercoat vehicles. I myself was not inquiring about having my vehicle undercoated but overheard a conversation the owner having a conversation with a customer one day that wanted it done. He told the customer he was able to do it but would not do it because he said in the long run it can cause a lot more problems then solve. He recommended the customer did not undercoat his vehicle, but if he wanted it done gave him the names of a couple other shops in teh area that would do it. The owner said he just was not comfortable in undercoating vehicles.
I never thought about it much after that day, but this post rejogged my memory a bit. Any idea why he would recommend NOT getting the vehicle undercoated? I live in Maine, we have lots of snow and salted roads up here...
Cheers,
Josh
Owning a Jeep makes a heroin addiction look like a vague yearn for something salty...
2002 Inline 6 TJ-X 4.0, D30/D35 w.4:56s
2inch BDS Full Coil Suspension, Incubus 511 Rims, 33inch Mickey Thompson ATZ, Bestop HighRock Front (w/Stainless Grill Guard) and Rear Bumper, KC SlimLites, Custom "TJ" Tail Light Covers
When I Die, Bury me in my JEEP. 'Cause it's never been in a hole it couldn't get out of! : )
TJoshX is offline   Reply With Quote
Old 09-14-2009, 07:50 AM   #14
LocknRoll
Josh
I'm just across the border from you in St. Andrews...same nasty metal eating salt/sand mixture on our winter roads.
Was the outfitter referring to undercoating a vehicle using Line-x or one of the annual rustproofing type treatments? On a vehicle which has already started to rust, that would make sense.
Can't think of any drawbacks to using a fluid film type treatment...other than everything being greasy/oily under the Yeep...anybody?
Old 09-14-2009, 08:35 AM   #15
TJamz
TJamz's Avatar
Try Rust Bullet. Plus disreguard my above post I made about usig the rubberized stuff.
Just ake a look athe the writup I did on removing the rubber coating and replacing w/ Rustbullet products:
www.jeepforum.com/forum/f9/replacing-undercoat-advice-pics-753713/
TJamz is offline   Reply With Quote
Glock Forum
