Need some help (shuddering) - JeepForum.com
post #1 of 12 Old 04-08-2008, 05:50 PM Thread Starter
BlackJeepin
While at a stop light, or a drivethrough or wherever, my jeep likes to surge and shudder. The rpms go from 500 to 250 then to 700, its a weird problem. When i go to take off after said problem it boggs down and acts like it wants to die, then it stutters more, then it goes. I get a CEL after putting gas in it.
Does anyone know what might be going on here, i have a 99 wrangler with an automatic transmission
Black Jeep Club member #126
Now you have the best of both worlds. A relationship that won't be universally mocked and scorned and hot cousin sex. And that's important.
Taken from another website, hell of a convo
BlackJeepin is offline
post #2 of 12 Old 04-08-2008, 08:41 PM
badoosh27
badoosh27's Avatar
run some seafoam through it and it should clean all that crap out and smooth it out. search seafoam on here, theres tons of threads of how to use it. sorry, im too lazy to explain it right now...
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
badoosh27 is offline
post #3 of 12 Old 04-08-2008, 09:15 PM
Xlr8n
1967 JK Wrangler
o...oo...oohh k..k..k..kkay....II II III'llll t.t...t....ttt...ttry to hhhehhehhelllppp.
Xlr8n is offline
post #4 of 12 Old 04-09-2008, 01:00 PM
badoosh27
badoosh27's Avatar
i see what you did there...
post #5 of 12 Old 04-09-2008, 01:10 PM
jeeptinker78
Check your trouble codes. Mine was doing the same thing. Ended up being bad O2 sensors.
jeeptinker78 is offline
post #6 of 12 Old 04-09-2008, 01:27 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Th th th th aaaaaaaats fuu fnn fnn ffffuny.
TheBoogieman is offline
post #7 of 12 Old 04-09-2008, 01:41 PM Thread Starter
BlackJeepin
Thanks for the responses...o2 sensor is highly likely, mine have never been replaced, 83,000 miles.
I am also gonna run the seafoam through it to
post #8 of 12 Old 04-09-2008, 01:41 PM
Silver04TJ
Mine was doing about the same thing. CEL throwing P121,122,123 codes. When I would pull out and give it gas it would bog down then all of a sudden take off. Changed the TPS and it runs fine now.
Silver 2004 Jeep Wrangler Sport
3.5" Rubicon Express Standard lift,
Cepek DC-1 15x10 Black wheels,
33x12.5x15 Cepek Fun Country II!!
M8000 Warn Winch with in cab controls
And the accessory every Jeep should have...DIRT/MUD!
Silver04TJ is offline
post #9 of 12 Old 04-09-2008, 01:49 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A bad 02 sensor isn't likely to cause anything worse than the engine to run too rich which makes it run more sluggishly with poorer fuel economy. RPMs that are eratic or surging are more commonly caused by a dirty IAC (idle air controller) which can be cleaned, or a dirty TPS (throttle position sensor) which cannot be cleaned, only replaced.
Jerry Bransford is offline
post #10 of 12 Old 06-03-2008, 05:04 PM
MrRandyRhoads
Sorry to bump this older thread, but I have a possible solution to the CEL after filling up. When I first got my Jeep, I would get a CEL after every fill up so I called the dealership thinking something was wrong. One of the techs asked me how many times the gas cap clicked when I screwed it back on. They told me that if you screw it on too tightly or leave it too loose, the pressure (or lack thereof) will cause the CEL.
To remedy this problem, screw the cap on until it clicks 3 times...no more, no less. I thought it was utter crap until I tried it, and sure enough, I haven't had a CEL since.
MrRandyRhoads is offline
post #11 of 12 Old 06-03-2008, 05:10 PM
Jerry Bransford
Administrator
You can't get the gas cap on too tight, it ratchets once it gets to the correct tightness. The OBD system check depends on that gas gap being absolutely air tight so getting on "too tight" (impossible to do) won't cause a CEL. 3 clicks, 10 clicks... all the same. Mine probably clicks 8-10 times when I spin it down quickly after filling up.
post #12 of 12 Old 06-03-2008, 05:39 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
I don't think Sea Foam will help. Not saying it won't, but I think it's a bad sensor. I would pull all of the sensors in the intake area out and wipe them down with some isopropyl alcohol. If that doesn't fix it, I would replace the IAC and MAF sensors.
Agreed. Urban legends.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
Jeep is shuddering...? HMTwin TJ Wrangler Technical Forum 4 11-21-2009 05:11 PM
tranny shuddering?? Beltfed09 JK Wrangler Technical Forum 9 08-28-2009 10:46 PM
Bogging/Shuddering in 4th, 5th, 6th any RPM Jordon83 JK Wrangler Technical Forum 4 07-07-2009 09:40 AM
crazy shuddering ? JaredBoys JK Wrangler Technical Forum 13 03-30-2008 07:22 PM
Shuddering on takeoff... RenegadeYJ17 YJ Wrangler Technical Forum 3 04-13-2003 10:07 PM
