Need some help with my Rubicon Locker` - JeepForum.com
post #1 of 6 Old 08-29-2009, 12:44 PM Thread Starter
rubbertoe
So i installed a D44 rear out of a rubicon into my TJ, and i noticed there are two wires coming out of the diff, i think one is purple and the other black, is this a sensor that tells me when the locker is engaged or not? i checked for continuity when i turned the locker pump on and when i had it off and i wouldnt read anything, if anyone has more info on what these two wires are for that would be great!
rubbertoe is offline
post #2 of 6 Old 08-29-2009, 01:02 PM
472cid
yes it just indicates a locked axle
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs
472cid is offline
post #3 of 6 Old 08-29-2009, 01:03 PM
472cid
I hooked one side to ground and ran other wire to a light hooked keyed power to other side of light and when engaged the light comes on when axle is locked
472cid is offline
post #4 of 6 Old 08-29-2009, 01:15 PM
jdhallissey
You can get a switch that has a light on it. Wire the purple to the light side of the switch so that you don't have to wire it to another light or take anything else apart.
jdhallissey is offline
post #5 of 6 Old 08-29-2009, 01:18 PM
472cid
here is exactly what i ran mine into. it is a lighted switch and pretty cheap too. fits in factory switch openings too.OTRATTW buy them here The square with the gears in it lights up when locked
472cid is offline
post #6 of 6 Old 09-23-2009, 01:31 PM
bean66
Hey Did you install any type of "saftey" switch to prevent the lockers from being engaged accidentally?
Also is that switch a spst dpst spdt or dpdt ?
How did you wire them in?
bean66 is offline
Rubicon Locker Air Pump question (how to wire your Rubicon air pump) paultyler TJ Wrangler Technical Forum 172 04-25-2017 07:59 PM
rubicon air locker? PatrickMintun YJ Wrangler Technical Forum 10 06-20-2009 07:24 PM
rubicon locker? crazylj TJ Wrangler Technical Forum 6 03-22-2006 07:09 PM
ok got a rubicon locker 80cj5 YJ Wrangler Technical Forum 9 10-21-2005 03:22 PM
ARB air locker vs. Rubicon locker in my TJ Glass TJ Wrangler Technical Forum 27 08-09-2005 06:23 PM
