Need some advice from jeepin vets - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Need some advice from jeepin vets
3" BDS Suspension Lift Kit - Jeep JK 07-11Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Wrangler Weatherstripping
Unread 07-07-2015, 10:23 AM   #1
Fortmeier
A little brief history of what I currently run. 3.5" RE springs front and rear, 1" body lift, 1" mm lift, 35 general red letters, Highline fenders front, and upper and lower rough country short arms. Will be installing a UCF skid soon. This is a current daily driver and handles very well the the currie tie rod and drag link. a Few pictures below for the visual folk.
I've decided to lower it as the highline fenders have given me the opportunity to fit 37's with 2" coils and still have room to spare. The plan is to be low and capable for MOAB. Here's where I need advice. The CA's need replacing. Since I'm already spending the money for new ones I want to triangulate the rear and get rid of the track bar. I will be stretching down the road but not any time soon. Long arms are out of the question with 2" coils and the short arm geometry is not to my liking but works. Should I invest in manufacturing my own mid arms at this height? Or would you, yes you, stick with short arms? I'm an ME and have the capability to hash out a decent setup but need some advice as to whether it would be worth my time for the potential gain.
Fortmeier is offline   Reply With Quote Quick reply to this message
Unread 07-07-2015, 10:38 AM   #2
joe_jeep
my set up is sort of similar to yours, but on an ljr.
3.5 re coils, 35" general grabber reds, all currie arms and trackbar, zj tire rod and drag link.
i sold my bfg km2 37s, to get my 35" grabbers.
i get mid arms work sweet, i understand wanting to ditch the rear track bar too.
i just wonder at 2" springs, will u gain enough, to make the funds laid out to do it, a good investment.
you will get better geometry, and flatter arm angles, assuming its done well.
i just dont see it as a game changer, in ride, flex, or geometry, when u run 2" springs.
at 4" or more, then yes mid arms would be the way to go.
imho, with 2" springs, the short arms will be more than good enough.
the 2" bds springs,
with your current fox shocks (with altered mounts to support their length),
quality short arms (savvy, currie, rockmen, clayton, metalcloak),
metalcloak track bars,
would work really well (imho).
u got a sweet looking jeep, congrats!
good luck, what ever u choose to do.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is online now   Reply With Quote Quick reply to this message
Unread 07-07-2015, 12:29 PM   #3
Fortmeier
This was my initial thought but the fact that it will be my DD for a while makes me want the better ride quality on road. Thanks for the input though. Maybe I can just swap out the low hanging frame and axle mount brackets for low profile ones. That might make me a little more content with short arms.
Thank you sir
Unread 07-07-2015, 01:10 PM   #4
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Nice looking Jeep, well set up. My only comment has to do with your thoughts of going to 37" tires. Assuming your Rubicon is still running the standard Dana 44 axles, they're not really up to 37" tires. Your front Dana 44, with the exception of the center pumpkin, gears, and inner axle shaft, is all Dana 30 and not really up to anything larger than 35". My own Dana 44 axles are well built up with alloy inner/outer shafts, Warn hubs, CTM u-joints, stronger ball joints, bigger brakes, etc. but I'm still limiting them to 35" tires. It's reliable at 35", it wouldn't be if I went to 37's. Plus you'd need to beef up the brakes and depending on your existing axle ratio, regear to a lower axle ratio to go to the 37's.
Getting Savvy...
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread 07-07-2015, 02:05 PM   #5
DanielW
Junior Member
Nice rig, I think I see it parked in Bodo Park most days. Jerry's got a point, I think he runs 4:88's with his 35's also. How is your power with the 35's and 4:11?
DanielW is offline   Reply With Quote Quick reply to this message
Unread 07-07-2015, 03:01 PM   #6
Fortmeier
Originally Posted by Jerry Bransford View Post
My only comment has to do with your thoughts of going to 37" tires. .
My main reasoning behind 37's is if I decide to drop to 2" coils I'd like to gain clearance via tire size while staying low. But you also make a good point with the strength issue. The last thing I need is to bend axle housing and start wearing out parts faster than I can fund them.
Unread 07-07-2015, 03:05 PM   #7
Fortmeier
That would be me. Honestly the power isn't too bad. I live up Florida and can maintain 45 easily uphill in 4th around 2500 rpm and can even shift to 5th if I want to save a buck or two. Once my skid get's shipped my next item on the list is re-gearing to 4:88. Are you the one who owns the black and red LJ parked at the building near the harley dealership?
Unread 07-07-2015, 03:55 PM   #8
DanielW
Junior Member
No I have a white with black top LJ. My wife works up in Bodo, I pick her up for lunch some days. Is your jeep a automatic or manual...did not see that in your profile.
Unread 07-07-2015, 04:12 PM   #9
Fortmeier
I might have seen yours drive by before. It's a 6 speed manual. Should have went auto. Crawling manual is a hassle to say the least.
Unread 07-07-2015, 04:18 PM   #10
rda616
Be cautious when selecting a spring. The 2" springs are going to have a short free length in most cases and will unseat easily with shocks sized for most 3.5" lifts. Even the RE 3.5" springs are quite short by comparison to most in that lift height range. Those springs have one of the highest spring rates available for a TJ. It looks like they are unseating in one of your pics. That is a bad thing and results a loss of traction.
You may be well served trying something like a RC 2.5" spring which have very long free lengths vs most in the 2"-3" range. They aren't my favorite spring to use on a heavy rig, but you aren't looking to gain height, so they may be the right ticket.
rda616 is offline   Reply With Quote Quick reply to this message
Unread 07-08-2015, 08:05 AM   #11
Fortmeier
Thanks for the heads up. And good eye. They do in fact come unseated when stretched too far. I've been trying to address this problem but it seems the ultra stiff, as you mentioned high spring rate, RE coils need to go.
