Need Smoother Ride - JeepForum.com
post #1 of 17 Old 11-07-2006, 07:08 PM Thread Starter
GA TJ
Need Smoother Ride
Ive had my jeep for 3 years now with Rancho 5000s and MT baja claws, i dont think the ride can get any worse and rougher. Its time for new tires and shocks. Any suggestions on a good soft shock that will smooth the ride out a little bit?
thanks
Black 2003 Sahara
Auto 4.0
D30/D44 w/trac-lock
RE 3.5 Coils. 1.25 BL, 1"MML, All Teraflex arms,trac bars, and sway bars, Currie SYE/CV. Jeep Medic Belly up and engine skid, 33x12.50 MT Claws :(
GA TJ is offline
post #2 of 17 Old 11-07-2006, 07:12 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I personally like the James duff shocks $35 a piece. great at slow speeds and at high speeds. What tires are you going to? ATs MTs TSL style?
James duff designed these shocks after racing numerous years in his bronco including the baja 1000 and other places. I met him at a ECBR run when I went with a friend of mine. Really nice guy.
http://www.jamesduff.com/eb/suspension_components.html
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #3 of 17 Old 11-07-2006, 07:12 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Like ProComp's ES-3000 shock, Rancho's R5000 shock has a reputation for being extremely stiff, too stiff for a Wrangler. I'd go with OME (Old Man Emu) or perhaps Doetsch Tech DT-3000 shocks. Most hydraulic shocks ride ok (the ES-3000 and R5000 being two notable exceptions) with a few gas charged shocks like the OME and special Wrangler-only Bilstein 5100 also riding well... but most other gas-charged shocks are just plain too stiff.
Jerry Bransford is offline
post #4 of 17 Old 11-07-2006, 07:14 PM
AustinJeep
AustinJeep's Avatar
Hmmm I'm running OME shocks with the stock Rubi springs and don't care for the ride much. I'm told it would ride much better with different springs though
2005 Lime Green Rubicon.
5" Clayton Longarm/Nth Degree/OME
35" Nitto Muds 17" Pro Comp wheels
AustinJeep is offline
post #5 of 17 Old 11-08-2006, 03:10 AM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
my DT 3000's are smoother than my superlift, but still kind of a rough ride. i've heard the 8000's are a little better. i've ridden on OME's in a rubi, and it was night and day, but my lift is about 1.5" higher, so i xfer more shock via the control arms. people have said that the RE monotube are comparable to the OME's.
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
USN Hull number 54
Poor Boy is offline
post #6 of 17 Old 11-08-2006, 05:48 AM
Vinman
Question for the rough riding crew:
What air pressure are you running in your tires?
I run about 23-24 psi in my 35" MT/R's and can really notice a difference in ride by going just one psi higher.
Vince
Vinman is offline
post #7 of 17 Old 11-08-2006, 06:20 AM
mdm
Farm Wheeler
I put a set of Skyjacker 7000 Hydro shocks on last weekend. The packaging they came in makes me wonder if they are rebadged Rancho 7000s. Other than the box, they have no manufacture identification on them at all. They are towards the lower end of the price range. I've never owned a "normal" car, I've spent my years in vehicles and bikes with pretty stiff suspensions so I'm probably not as sensitive to ride quality as others are but they give me a pretty good ride.
I have to agree about tire pressure being an issue. Many people I've seen complain about a hard ride had their tires over inflated. Several at the PSI (max PSI for Max load) shown on the sidewall. When the pressure was set at a reasonable PSI the ride magically went from bone jarring to smooth.
mdm is offline
post #8 of 17 Old 11-08-2006, 07:14 AM
SecondTJ
SecondTJ's Avatar
ome for a smooth ride.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #9 of 17 Old 11-08-2006, 07:21 AM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
i am running 26 psi in mine. i could probably take it down a couple, but i'm afraid to under-inflate it. i can't find any place flat for a chalk test in frickin belgium.
USN Hull number 54
Poor Boy is offline
post #10 of 17 Old 11-08-2006, 07:36 AM
dieselcrackel
2017 JK Wrangler
I installed the procomp MX6 adj shocks. They ride better then stock shocks. I hear most of procomp shocks but I can't complain about MX6's. I don't know if it because they are inverted or is it because I can adjust them to suit my needs
dieselcrackel is offline
post #11 of 17 Old 11-08-2006, 07:40 AM
mdm
Farm Wheeler
Belgium doesn't have parking lots?
There is a math process that will do the same thing as the chalk method for you.
On the sidewall of the tire you will find the max load/pressure of the tire.
For an example Iíll use a tire rated at 2270 lbs @ 50 psi and a vehicle that weighs 4850 lbs.
Step 1 - Multiply the max load times 4. This is the maximum weight your four tires can safely carry.
2270 lbs * 4 = 9080 lbs
Step 2 - Divide the weight of the vehicle (placard on driverís door jam) by the number you got in the first step. This is the percent of the max load you are actually carrying on the tires.
4850/9080 = 53%
Step 3 - Multiply the psi stated on the tire for max load by the percentage you got in step 2. This will give you an optimal pressure for you tire on the road.
50 psi * 53% = 27 psi
The chalk test and the math approach will usually give you very close answers.
These methods give you a start point for getting the psi that will give you even tire wear. Start at that point and go up/down a few lbs to get what you want. A few pounds more gives you better mpg. A few pounds down softens the ride more.
mdm is offline
post #12 of 17 Old 11-08-2006, 07:40 AM
DrMani
Live to Cut
DrMani's Avatar
x2 on the MX-6 shocks. I had Procomp ES-3000, rough ride. Night and day difference in ride.
A bad day on the trail is better than any other day.
No autopsy, no foul.
DrMani is offline
post #13 of 17 Old 11-08-2006, 09:07 AM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
4850/9080 = 53%
belgium has parking lots. and highways too. that's not my problem. i can't find a flat one i guess i'll have to do the math. thanks for that, i never even thought of it...
USN Hull number 54
Poor Boy is offline
post #14 of 17 Old 11-08-2006, 09:32 AM
Blu-Jacket
2009 JK Wrangler
I switched from stock to OME's and it made a big improvement in ride quality.
Blu-Jacket is offline
post #15 of 17 Old 11-08-2006, 09:56 AM
Ichabod1960
Have Jeep, Will Travel
Ichabod1960's Avatar
I just can't resist. If your looking for flat just drive up to Holland. I remember lots of very flat land from my visit to Eindhoven in 97.
Seriously though, the math route works really well. The hard part is getting an accurate weight on the Jeep. A visit to the truck stop may be in your future.
Drew
Originally Posted by Jerry Bransford
There's a great lower division class called "Writing for Effective Communications so you don't go through the rest of your life confusing everyone who reads what you write 101" at Washington State University. I highly recommend it.
Ichabod1960 is offline
Smoother ride Thug Nasty TJ Wrangler Technical Forum 9 10-02-2011 10:29 AM
Smoother ride? 91whiteYJ YJ Wrangler Technical Forum 5 11-27-2007 07:27 AM
Looking for a smoother ride.... Airborne4X4 TJ Wrangler Technical Forum 6 12-30-2006 08:31 AM
need a smoother ride rogasm TJ Wrangler Technical Forum 11 08-21-2004 06:08 PM
Shocks for a smoother ride aboynamedmoose YJ Wrangler Technical Forum 12 10-13-2002 11:46 AM
