need a smoother ride - JeepForum.com
post #1 of 12 Old 08-19-2004, 07:36 AM Thread Starter
rogasm
allright guys, this is getting rediculous. every little bump/crack in the road that i go over makes my whole jeep BOUNCE!!! not to mention the death wobble that i get at 42-50 mph. i have to get this worked out. any suggestions? steering stabilizers? i have a 2"BB and 31" tires. i just rotated my tires, which helped. thanks for everyone's help.
rogasm is offline
post #2 of 12 Old 08-19-2004, 07:38 AM
igofshn
Locked @ both ends
igofshn's Avatar
Tighten the bolts on the track bar. Have you done an alignment? What shocks are your running? How much air are you running in the tires?
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 12 Old 08-19-2004, 07:51 AM
StealthTJ
With regards to smoothing the ride out, your two biggest things (setup as your Jeep is) are the tire pressure, and the shocks.
As was already asked,
- What tire pressure are you running
- What shocks are you running.
The DW is smothing else.
A steering stabilizer (or lack of one), will neither cause, nor prevent, death wobble.
Fred
Base - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
Suspension- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
Misc - Tera 2wd lo.
Tires - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
Recovery - Warn XD9000i
StealthTJ is offline
post #4 of 12 Old 08-19-2004, 09:11 AM Thread Starter
rogasm
thanks for your help guys, i am not sure what pressure my tires are at right now, will check at lunch. still have stock shocks and it's probably a smart move to get some new ones. any suggestions?
rogasm is offline
post #5 of 12 Old 08-19-2004, 09:44 AM
BSoDAlptraum
BSoDAlptraum's Avatar
depends how much you are looking to spend...but i hear OME shocks are pretty good, and not too too pricey.
-Jeff
Patriot Blue Rubicon: Locked Stocker
i like 'em topless and covered in mud...
BSoDAlptraum is offline
post #6 of 12 Old 08-19-2004, 07:51 PM
ncb76
ncb76's Avatar
Try balancing your tires. I was getting some bad wobble at about 45 mph and having the fronts balanced fixed that. Since you are running the factory springs and shocks, it's probably the tire pressure.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
post #7 of 12 Old 08-20-2004, 07:27 AM
JeepinJohnny
I'm having the same issues after my BB install. It came with new shocks, D3000 or something like that. I lowered my tire pressure from 40 (shop pumped the up) to 30. That helped some, but the ride is still harsh & jarring. Will a different shock or different spring help? I drive 95% on-road.
I am going to lower the tranny this weekend to eliminate the vibration from the driveshaft.
I have a hard time with keeping the tires balanced. I just had them balanced along with an alignment last week, and the death wobble has come back strong 2 days afterwards. I've had them rebalanced 3 times since April, and each time, they needed it.
Does anyone know of an aftermarket seat that is built to absorb some of the jolts and soften the ride for the driver?
JeepinJohnny is offline
post #8 of 12 Old 08-20-2004, 09:27 AM
uglyprimate
eat more cheeseburgers and put more padding on your butt
uglyprimate is offline
post #9 of 12 Old 08-20-2004, 09:27 AM
Seapahn
Seapahn's Avatar
Mine rides like a cadillac on rx9000 shocks on the softest settings (9 firmness settings on each). Now I have the fronts at 1 and rears at 3 since I put the hard top back on. I do have a long arm lift though but the shocks are very nice.
Seapahn is offline
post #10 of 12 Old 08-20-2004, 07:01 PM
btolle
I put OME springs and shocks on my 04 and it made the ride much smoother.
Good shocks make a big difference.
I have heard complaints about the DT3000's being rough riders.
I also considered the Edlebrock's but the cost almost as much as OME's.
Bill Tolle
04 Sahara
04 Liberty
btolle is offline
post #11 of 12 Old 08-21-2004, 05:58 PM
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
Rancho RS9000X - $90 each but you can flip 'em to the softest setting when you want to and think you're in a Caddy...
2010 Sahara
04JeepTJ is offline
post #12 of 12 Old 08-21-2004, 06:08 PM
ChristopherJ
Resident Physician
ChristopherJ's Avatar
2017 JK Wrangler
Which are better, old man emu or the Rancho RS9000X? Not taking into account the price difference, which provides the smoothest ride plus longest travel?
ChristopherJ is offline
Smoother ride Thug Nasty TJ Wrangler Technical Forum 9 10-02-2011 10:29 AM
Smoother ride? 91whiteYJ YJ Wrangler Technical Forum 5 11-27-2007 07:27 AM
Looking for a smoother ride.... Airborne4X4 TJ Wrangler Technical Forum 6 12-30-2006 08:31 AM
Need Smoother Ride GA TJ TJ Wrangler Technical Forum 16 11-09-2006 02:47 AM
Shocks for a smoother ride aboynamedmoose YJ Wrangler Technical Forum 12 10-13-2002 11:46 AM
