Need part number for slip yoke seal? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Need part number for slip yoke seal?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 09-19-2009, 02:11 PM   #1
IH8ROADZ
My stock slip yoke is spewing atf out of it I need to order the seal so I can stop trying to top off the TC which is a royal PITA. Its the seal connecting the driveshaft into the housing.
http://i24.photobucket.com/albums/c14/favre440/SYE.jpg
IH8ROADZ is offline   Reply With Quote
Unread 09-19-2009, 02:35 PM   #2
Jonny Jeep
Jonny Jeep's Avatar
Timken part number is 4370N.
Jeep part number is 4798117.
Should be able to get one much cheaper than the dealer.
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it."
Adam Cooper (19th century)
Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm
Online factory service manuals (FSMs) can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm
If the link doesn't work properly, look for the service manual link under Jeep Resources at the bottom of the page.
Parts list PDFs available from http://www.berrysprinter.com/jeepparts.php
Jonny Jeep is offline   Reply With Quote
Unread 09-20-2009, 08:23 PM   #3
IH8ROADZ
As far as replacing this seal is it just a matter of popping off the rear driveshaft unbolting the slip yoke and pop old seal out and new one in or will I have to open up the transfer case to replace this seal?
