| Moto Alliance Viper Elite 8,000lb Winch Giveaway! |
| Jeep Registry | Register | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
Need opinion on LIFTS and TIRES!!!
#2 |
What are you going to be using the jeep for, daily driver/offroading or strictly offroading? Keep in mind that the bigger you go the bigger you spend.
02 Sahara/ BFG AT 33"x12.5/ 15x8 Cragar Soft 8's, 4" BS/ 3.5" Rubicon Express lift/ Warn front bumper |
#3 |
driving not off roading but want it to look good and be high
#4 |
also sorry i forgot to add, when lifting 4" do i need to change any thing or just bolt it on?
#5 |
All the answers you seek can be found in this thread.
http://www.jeepforum.com/forum/showthread.php?t=206210 |
#6 | |
Of course you can do without the three listed above but i wouldn't IMO. Most 4" lift kits are bolt ons. When going that high on a TJ, you may experience vibrations in the rear driveshaft. This is a result of the shaft angle getting too extreme and you will need to fix this. Be sure to have a Motor Mount Lift/Body Lift or Slip yoke eliminator kit/adjustable upper control arms on your list
2001 XJ Sport 4.5" RC LA Custom snorkel Detours/winch Flux Capacitor Heat Machine |
#7 | ||
Sounds like you want a cheap route to good looks...and if your doing it for looks you do NOT want to fork out the cash for 35's
My suggestion... RE Budget Boost-2" suspension lift that includes shocks 1" Body lift-lifts the tub off of the frame 1" This will allow you to run 32's without spending alot of money. If you are dead-set on 33's though... Rubicon Express(RE) 3.5" Standard kit- 3 1/2" suspension lift which usually nets around 4-4.5" of lift RE extreme monotube shocks I have the RE 3.5" Standard and I enjoy it. It's a great lift for a beginner and easily upgradeable for when you get into 4wheeling more often.
#8 |
well my other question is if i put on the 4" lift would 35's fit like that or do i need to cut something? also does someone have a pic of one lifted only 4" susp no body and 35s? thanks
#9 |
It will fit, but anytime you go over 3-3.5" on a TJ, you may or may not need a slip yoke eliminator and cv driveshaft ($430) depending on the Jeep (everyone is different). I would second the 2" budget boost with OME shocks and 1" BL with 32s or 33s.
98 XJ Sport with 4.5" lift, 31" MTZs, and other goodies. |
#10 | |
3"-4.5" for 33's 5+" for 35's However, there is always an exception! Rancho makes a 4" lift (Rockcrawler version....about $1000.00) that they claim clears 35's (it does, I have a friend with one.....long bump stops limit up travel and soft springs get them a pretty flexy ride too). At 4" your most likely going to have driveline vibes so a slip yoke eliminator would most likely be needed. With the SYE, comes a need for adjustable rear upper control arms. With the Adj. rear upper arms comes a need for rear shock relocators. etc......etc.......etc...... Yea, and Brake upgrades, steering upgrades etc...... Plan on that "cheap" lift costing you about $3K when it's all said and done. Bill
Gone but not forgotten: 05 TJ Sport RK 5.5" Long Arm, 1" Daystar BL M.O.R.E. Bombproof 1" MML AA SYE, RE CV Driveshaft 4.56's, ARB Super 30 Front, Detroit D44 w/Alloys Rear 35" BFG MT's RK X-Factor steering, Currie Anti-Rock, Nth oil pan skid, Rock Crusher Diff covers Line X OBA (Viair 450c System) Trail Gear Rockers Custom rear bumper/swing out |
#11 |
Just some input for you. I went with a Teraflex 3T kit and was able to fit 33x12.50 MTR's on 15x10's without any problems, or other pieces like new drive shaft/slip yoke etc... and still have room to play. I also use mine as a dailly driver of 80 miles a day and alot of compliments on the look of the height. 2000 TJ Sport
Steven |
#12 |
size and skill matter
I ran 33s on the trail with 4" of lift. Now i run 36s on the trail and I added the 1" body lift. They rub a little, but you have to adjust your bumpstops to keep them from rubbing. At full flex and 4" my 33s rubbed the flares a little, but that was when i was almost picking a tire off the ground. If you go with 4" you are pushing it on the SYE. I needed one, but i waited about a year or so to do it after the lift and tires. What a lot of people do to get around the SYE is run a 3 inch suspention and a 1 inch body lift. Hope this helps, what ever you do DON"T GET SKYJACKER. my lift flexes great, but it squeaks like no other and the only way to fix the squeak is to replace all the heim joints (14 plus the one on the TracK bar). Just a thought. Also skyjacker rides really rough
Tyler BRIGHT SILVER METALLIC TJ Custom Streeeeeetched, Locked, and 36s. All work done by me... www.kifourwheelers.com Other Toys... 1946 CJ2a to be restored My 1946 CJ2a 1948 CJ2a to be parted out My 1948 CJ2a 1995 K2500 Suburban~ NO SPARK PLUGS Dents..."It's only a flesh wound" For Sale... Dana 30 3.73 R&P only, RE rear TJ 5.5" coils, email/PM for details For Sale19 gallon TJ fuel tank and factory skid My Build Thread... TJ stretch on coils |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Opinion: Do my tires look undersized for my lifts + flair | c4ifford | JK Technical Forum | 28 | 12-15-2009 11:50 AM |
| tires/rims opinion.. | fullcollapse | TJ Technical Forum | 1 | 06-08-2009 04:18 AM |
| What's everyone's opinion on Rough Country suspension lifts? | joet7287 | TJ Technical Forum | 71 | 04-03-2009 03:53 PM |
| Opinion on Black Diamond Lifts | Jeep Man 10 | YJ Technical Forum | 17 | 03-12-2008 12:47 PM |
| Trailmaster lifts? *Need opinion* | BeatAChevy289 | YJ Technical Forum | 3 | 12-18-2004 01:35 PM |
The time now is 08:36 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
