Need a new track bar - JeepForum.com
post #1 of 30 Old 08-18-2012, 09:52 AM Thread Starter
Wisconsinvette
Just got my first Wrangler. I took it in to have the front end looked over and they said my track bar has some play. They cannot identify the brand so they said I may need a new one. What are your suggestions for a front track bar. The Jeep is lifted 4".
Wisconsinvette is offline
post #2 of 30 Old 08-18-2012, 10:08 AM
JeSimmers
JeSimmers's Avatar
JeSimmers is offline
post #3 of 30 Old 08-18-2012, 10:23 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
Check it out yourself so you don't buy one for no reason.Most mechanics don't know Jack about Jeep suspensions.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #4 of 30 Old 08-18-2012, 10:42 AM Thread Starter
Wisconsinvette
Thanks for the words of caution. I actually took it to the local chevy dealer because some of the mechanics have lifted Jeeps and belong to the local Jeep club and have off road experience.
post #5 of 30 Old 08-18-2012, 06:15 PM
Gary2
And they couldn't identify the brand you have presently ....... I bet if you post a picture some one on this forum can. I would agree , get under there and check for yourself if for nothing else to learn what a bad one looks like.
Gary2 is offline
post #6 of 30 Old 08-18-2012, 06:58 PM Thread Starter
Wisconsinvette
I have been poking around trying to get to know the parts. So is the link above one of the better options for a new one?
post #7 of 30 Old 08-18-2012, 07:02 PM
asim04LJ
Looks like you need to get rid of the dropped pitman arm.
asim04LJ is offline
post #8 of 30 Old 08-18-2012, 07:12 PM
asim04LJ
Also, looks like you need to get rid of that dropped track bar bracket on the axle. Seems like Rough Country to me.
asim04LJ is offline
post #9 of 30 Old 08-18-2012, 07:16 PM
WhiteOut
WhiteOut's Avatar
And the dual stabilizers.
Seems like the lift was "put together" by someone with very little knowledge.
WhiteOut is offline
post #10 of 30 Old 08-18-2012, 07:34 PM Thread Starter
Wisconsinvette
I also have very little knowledge. Can you recommend what I need to replace and with what?
1. Dropped pitman arm. What should I look for?
2. Yes the lift is rough country so you are probably right. So the track bar should be attached where the bolt above the dropped bracket is?
3. I should just drop the whole stabilizer setup?
Thanks
post #11 of 30 Old 08-18-2012, 07:39 PM
asim04LJ
Replace the dropped pitman arm for a stock oem arm and get rid of that dropped bracket on the axle end of the track bar.
2. Yes
Edit: The track bar maybe a Superlift.
asim04LJ is offline
post #12 of 30 Old 08-18-2012, 07:53 PM
Jeepson33s
3. Get a stabilizer to put in the stock location...just one.
The track bar does not look like rough country as the joint on the frame end is on the opposite end of the one they sell.
Is it possible it could be installed the wrong way? that's what it looks like.
2003 Wrangler Rubicon Intense Blue- 4" Rough Country X-Series lift - Bilstein 5100 Shocks - Currie RockJock V-Bumper and Rock Crawler Rear bumper - Badlands 12K winch - Tom Woods DS - KC Slimlites - KC Headlight conversion with 4300K HID - 285/75/16 BFG MT KM2 on Rubicon Wheels
Jeepson33s is offline
post #13 of 30 Old 08-18-2012, 07:56 PM Thread Starter
Wisconsinvette
I will get am OEM pitman arm but will I have to replace the drag link? Why would they have added the dropped pitman arm?
I will get rid of the dropped bracket and move the track bar up to the other bolt. Why would they have added the dropped bracket? I still have an isue with the track bar being a bit loose. If I cannot get new bushings after looking at rough country and superlift what is a good replacement other than what is mentioned above?
post #14 of 30 Old 08-18-2012, 07:59 PM
asim04LJ
That's what I was thinking but then whoever installed it didn't put the dropped bracket on the frame side if it's the same RC track bar I have.
asim04LJ is offline
post #15 of 30 Old 08-18-2012, 08:01 PM Thread Starter
Wisconsinvette
Can you point me to this setup?
JKS track bar back to factory track bar - Options? fromme TJ Wrangler Technical Forum 53 04-12-2013 03:27 PM
Rear Track bar ? should i get the extension bracket or a adjustable track bar odyssey017 TJ Wrangler Technical Forum 8 05-10-2011 08:20 AM
Track bar extension bracket versus adjustable track bars? JohnnyWhitehead TJ Wrangler Technical Forum 7 01-03-2011 09:20 AM
Need some good pictures of a rear track bar or some kind of track bar mcgarys2007 YJ Wrangler Technical Forum 17 09-18-2007 12:59 PM
Front Track Bar & Rear Track Bar Bracket mossimo19 TJ Wrangler Technical Forum 4 09-14-2005 07:56 PM
