-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Need a little tech help. (http://www.jeepforum.com/forum/f9/need-little-tech-help-258397/)
tautog27 04-05-2006 11:02 AM
I have two questions for you guys. I have a 04 Rubicon with a Fab-Tec adjustable lift, 8000lbs. Warn on the front, and a few other light modifications. I bought the lift, really to level everything out once I added the winch, which sunk the front. The adjustable towers are all the way extended in the front and not at all in the back. The problem I'm having is when traveling on the road; even the smallest bump causes the rear to bounce multiple times before settling down. Every time I drive it, I feel like I've joined the PBR. I'm almost considering buying another lift to remedy the problem, but then I'm concerned that again the Jeep will be way unlevel again. Second, does anyone know where to buy, or how to build a hand throttle? I saw a few guys running them at Tellico, and would love to get my hands on one; they really seem to help keep everything smooth on those long, tricky climbs. Any suggestions, thoughts, or ideas would be greatly appreciated.
Thanks, Ross
lightfighter 04-05-2006 11:41 AM
http://www.rubiconexpress.com/dynami...p?folderid=785 hand throttle at rubicon express.
RUB1CON 04-05-2006 11:42 AM
I cant help you much with the lift situation dont know anyone who runs the Adj. spacers maybe raise the rear end a little, sounds kind of odd but the hand throttle check www.redrock4x4.com he has good prices and a forum sponsor and also I think you can get a write up here on it www.stu-offroad.com
tautog27 04-05-2006 02:29 PM
RE: Need a little tech help
Thanks guys, I purchased the hand throttle from Rubicon Express. I was thinking, is it possible I've blown out my rear shocks, and that's what is causing the bounce? There almost new, but I guess anything is possible?
1BLKJP 04-05-2006 02:44 PM
If you push up and down on the rear bumper and then let go does it continue to bounce or does it stop as soon as you stop putting tension on it?
tautog27 04-05-2006 03:47 PM
Jack,
Pushing down on the bumper is pretty easy, it quickly returns, but with an ever so slight bounce at the top of it's cycle. I was also thinking it's much worse with the hard top on, and flat out terrible with passengers in the rear, it really bottoms out on the trail. I've tightened up the springs, but as soon as I start doing that, the rear sits substaintly higher than the front? I'm really at a loss, if I put spring blocks are anything else in there, I'll lose the articulation............... HELP!
COwheeler 04-05-2006 04:21 PM
Sounds like the shocks. For a test, you can throw the stock shocks back on there. They won't be long enough for flexing and such, but they'll be fine for testing the theory.
tautog27 04-05-2006 04:27 PM
Thanks, I'll switch them out this weekend, and see if that ends up being the problem.
tautog27 04-21-2006 01:35 PM
Thanks, guys! Switching out the shocks fixed the problem. I guess the shocks that came with lift kit were to large. The hand throttle came today, hopefully I'll get a chance to intall it this weekend. Thanks again!!!! Ross
The time now is 11:54 PM.
