Need a lift for my DD 05 LJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Need a lift for my DD 05 LJ
JK specific skid plates from Clayton Off Road Mfg.RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comStainless Steel Door Hinge Pins
Unread 06-04-2013, 03:35 PM   #1
slim163
Ok, first post. I recently acquired a 2005 LJ Automatic with a 4.0. It currently has an unknown mild body lift with 33s, but there is no other mods to the Jeep at all. I want to start from scratch, and my preference would be to put 35 12.5s on it, and I'm really interested in having a great road vehicle that is suitable for the highway, but has the capacity to have fun off road.
I want to do it right the first time, and not buy junk, so the question is where do I start, and what would be on my shopping list for the lift (i.e. do i need brake lines, cv, sye, etc.?) Trying to make things simple for me to understand, because I have no experience, but the capacity to learn. Thanks.
slim163 is offline   Reply With Quote
Unread 06-04-2013, 04:15 PM   #2
JBTJ
Use the search function and you will find a ton of info that will keep you reading for days. But yes you will need to upgrade the brakes, steering and a few other items. It won't be cheap.
JBTJ is offline   Reply With Quote
Unread 06-04-2013, 05:08 PM   #3
Ironhead
there are many ways to get to 35's, the constants are upgraded brakes, steering, gears.
then it goes to type of lift and how you'll stuff the tires under it
SL
SL+BL
Flat fenders/high-lined fenders
almost everything has pros and cons, thats where reading build threads, reviews, and searching through this forum helps save a lot of money and gets you a quality rig
Ironhead is offline   Reply With Quote
Unread 06-04-2013, 05:09 PM   #4
slim163
Definitely doing my share of reading. Thanks. dont like the look of the body lifts. Just looking for some simple to understand what to get opinions.
Unread 06-04-2013, 05:12 PM   #5
Ironhead
Originally Posted by slim163 View Post
Definitely doing my share of reading. Thanks. not Just looking for some simple to understand what to get opinions.
excellent, once you get an idea of how you want to do it, make a plan. read some more, then after throwing away that plan, make another one.
ask questions along the way to help guide your plan and your build. just about anything you can think about doing to a jeep has been done 100 times, and we get the benefit of learning from others mistakes
and the more info you have in your profile the better, it helps others when answering your questions
Unread 06-04-2013, 05:25 PM   #6
slim163
I will do that thanks
Unread 06-04-2013, 06:08 PM   #7
BimotaBruce
BimotaBruce's Avatar
We've got the same Jeep, and I've been through the same thing. Happy to help with photos (PM me) or anything else I've learned.
After a bit of experimentation, I've ended up piecing together a Currie kit. You just can't go wrong with their stuff (or some permutations of it available from Savvy Off Road).
It fits, it works (street & trail), & it's high quality.
Good luck....the LJ's a great starting platform!
MetalCloak Overlines, 4" Currie springs & CA's, 1" BL, Rancho 9000's, 35" MTR's, D44's w/ARB's & 4.27's, RCV & Superior Axles, 241 TC, UCF TummyTuck, GenRight mini-boatside sliders DirtWorx bumpers, OR Fab sportcage, Viair OBA, Savvy GTS
BimotaBruce is offline   Reply With Quote
Unread 06-04-2013, 06:18 PM   #8
slim163
Thanks ill look into that one
Unread 06-04-2013, 07:35 PM   #9
biffgnar
biffgnar's Avatar
http://www.jeepforum.com/forum/f9/i-...-my-tj-751873/
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is online now   Reply With Quote
Unread 06-04-2013, 08:47 PM   #10
tyvanwie
tyvanwie's Avatar
Edit: never mind. Not gonna bother.
Sent from my iForum using JeepPhone
MY BUILD THREAD
MY FITNESS LOG/TRANSFORMATION
JK AND TJ PARTS FOR SALE
I'm pretty sure I know what I'm talking about. I think...
tyvanwie is online now   Reply With Quote
