need info for gear swap, starting point - JeepForum.com
post #1 of 2 Old 09-13-2009, 10:19 AM Thread Starter
johnny9
i cant find the info i need and ive searched for 2 days..i just got 4.56 gears for my 97 tj.got detroit lockers and everything but master install kit.
will the master kit give me a starting point as far as the shims go??
when i remove the gears in have now will the shims be put in the same place on the new ring and pinion as a starting point to start setting it all up?
i have all the tools,magnetic dial indicators,calipers,depth gauges etc and know how to use them but this will be the first time in 20 yrs since ive done a gear swap but shouldnt have a problem..
just not finding the info id like to see..if anyone can help,,your appreciated
johnny9 is offline
post #2 of 2 Old 09-13-2009, 10:37 AM
YJ_Aaron
Yes the shims under the inner race will be a good starting point. A lot of gears will give you a +/- and then so many ten thousandths to change from that point. I always find that gets me within 2 or 3 changes of shims.
Remember when you change the shims on the pinion, the shims to set backlash won't be correct. I always make the old bearings setup bearings by honing them out so they slide on and off the carrier.
91 YJ rebuild! Rush to get it driving/wheeling.
YJ_Aaron is offline
cross over point in gear change. ARB locker postaldave YJ Wrangler Technical Forum 14 01-22-2010 05:54 PM
Carrier break point for gear ratio on a 8.8 2000jeeper TJ Wrangler Technical Forum 2 06-04-2009 06:31 AM
Starting a Local Jeep/4X4 club....info please!!!! 97casteeltj Wrangler General Discussion 6 08-17-2008 07:14 PM
Heres the starting point. corvetteguy YJ Wrangler Technical Forum 8 01-11-2007 11:59 AM
Starting in 2ng gear fxbrry TJ Wrangler Technical Forum 2 07-21-2006 05:57 PM
