#1 | |
Need Help Wiring
so right now on my rig im running a uniden CB and PIAA lights, both i have connected right to my battery
.what i want to do is wire them to my starter or set them up so they wont be on or drain my battery when my car is off. any diagrams would help.
Where did i put my doors? |
#2 |
want it rite or rite now?
use the spare fuse location in the fuse box behind the glove box...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#3 | |
the PIAAs should be run through a relay and the relay should be turned on by a switch on your dash that is wired to 'switched' power. you can do the same thing with the CB radio-but wire the relay to turn on with the ignition.
there shouldnt be any draw from the relay in the 'standby' state. running a cb and PIAAs correctly should not kill your battery. i build emergency vehicles with 15 lights/lightbars/comps/modems etc. wire it right and you wont have any issues. look for relay diagrams here under the stickys or a search. i will be adding a diagram page to my sight soon too.
Custom Long Arm with 14" Fox CO Front and Rear D60 KP Front and D60 FF Rear with 5.38s 40" Maxxis Trepadors 6.1 HEMI in process: scaple, clamps...pressure-very good doctor, she's coming along... i need fluids... http://www.jeepforum.com/forum/f9/6-1-hemi-lj-madness-mayhem-1013800/ http://www.jeepforum.com/forum/f22/fire-breathing-left-over-unlimited-1068902/ www.badinfluenceracing.net relays, wiring systems and components, parts, diagrams, tech tips and new store. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
