Need help with transfer case leak - JeepForum.com
post #1 of 11 Old 08-15-2009, 12:22 PM Thread Starter
SmackLayer
I have a pretty bad transmission fluid leak on a used 2000 wrangler I just bought. Looks like it is coming out of the transfer case. Is the transfer case is missing a bolt? Take a look at the picture. Should there be bolt there? This looks like this is where the coming from as it is the only place where I can see clean tranny fluid. Problem is that it doesn't really leak when it is stopped, only can see it dripping right after it has been driven and I can't take the skid plate off fast enough to see where it is really leaking from.
Any help or ideas.
Thanks
SmackLayer is offline
post #2 of 11 Old 08-15-2009, 12:29 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, there should be a nut on that stud. There rest are probably loose too.
There really shouldn't be any fluid in that area though. The tranny should seal up at the rear, and the T-case should also be sealed.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 11 Old 08-15-2009, 01:12 PM
F9K9
F9K9's Avatar
Check your ATF level in the tranny. It may require it to be in neutral (check the wording on the tranny dip stick) to check it. It is not uncommon to loose ATF from the rear tranny seal and seep into the transfer case.
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #4 of 11 Old 08-15-2009, 01:19 PM Thread Starter
SmackLayer
ATF level is good.
Where is the tranny seal?
post #5 of 11 Old 08-15-2009, 01:26 PM
F9K9
F9K9's Avatar
It's at the rear output of the tranny. There is a void between the tranny and TC. I wouldn't worry about that until you torque up the two together and see if it is still leaking. Just make sure that the fluid levels are good in both before panicking.
F9K9 is offline
post #6 of 11 Old 08-15-2009, 01:33 PM Thread Starter
SmackLayer
thank, do you happen to know the size of that mssing nut? I can't get the others off with any ease to take with me to the auto parts store
post #7 of 11 Old 08-15-2009, 01:41 PM
F9K9
F9K9's Avatar
Sorry, No, I do not know off hand.
F9K9 is offline
post #8 of 11 Old 08-15-2009, 03:00 PM
jamiedude
jamiedude's Avatar
1989 FSJ Wagoneer
your leak is probable from there
i wanna know why that bolt is missing and what was he doing in there anyway ( the previous owner )
paranoia strikes me when csi has a marathon on tv
jamiedude is offline
post #9 of 11 Old 08-15-2009, 03:11 PM Thread Starter
SmackLayer
I have no idea what previous owner was doing down there. I am slowy finding all sorts of weirdness on this vehicle. Anyway, does anyone know this bolt size?? Otherwise I just gonna have to buy one of everything that looks close and try em out.
post #10 of 11 Old 08-15-2009, 09:00 PM
jamiedude
jamiedude's Avatar
1989 FSJ Wagoneer
ABSOLUTELY NOT!!!
use your keen wits and intelligence to narrow the mass buying down
take one of the other ones off, head to a local hardware store. or one you know that has a thread display.
or take it and find a bolt that will fit it that way you'll find out the bolts measurement, pitch, diameter, why people are missing in its family, etc.
post #11 of 11 Old 08-15-2009, 09:26 PM Thread Starter
SmackLayer
Well, I couldn't easily get any of the others off. I didn't have a deep enough socket and I didn't want to strip it with a wrench.
There were only three different ones at the auto parts store and they were only like $.39 each, so I just got all three. In case anyone else needs to know it is a 3/8 - 24.
Transfer Case Leak Shane64 TJ Wrangler Technical Forum 12 05-28-2008 07:30 PM
Transfer Case Leak SWR73 TJ Wrangler Technical Forum 2 01-07-2008 09:53 AM
transfer case leak garin3 YJ Wrangler Technical Forum 0 05-04-2006 06:11 PM
transfer case leak erendon YJ Wrangler Technical Forum 7 03-24-2006 11:16 AM
'91 YJ Transfer Case Leak BamaRulz YJ Wrangler Technical Forum 3 02-16-2003 09:20 PM
