Quantcast Need Help!!! Throttle wide open when starting - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Need Help!!! Throttle wide open when starting
Truck-Lite's New LED Headlamp SeriesTJ 5.25" Speaker Adapters - NalinMFGCURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee!
Old 05-21-2005, 02:32 AM   #1
NCST8TJ
I've been lurking here for awhile and learned a lot from you guys, but couldn't really find anything about this. Just finished changing the manifold gasket on a 99 TJ, and the throttle pegs out wide open when I crank the engine. All connections and linkages look fine. Everything looks Ok as far as the manifold gasket goes. Any help would be greatly appreciated (supposed to hit the trails Sunday)
NCST8TJ is offline   Reply With Quote
Old 05-21-2005, 07:05 AM   #2
RockRunner85
When you say pegs out you mean it revs way up without you stepping on the gas meanig the throttle plate is closed. If so you have a leak in the manifold somewhere.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
The Reptile File
A discussion forum on geckos, lizards, snakes, and other reptiles.
RockRunner85 is offline   Reply With Quote
Old 05-21-2005, 12:46 PM   #3
NakedJeeper
Agree with what RockRunner said. Vacuum leak. Take the manifold bolts out and reseat it if you have to.
www.NakedJeep.com
NakedJeeper is offline   Reply With Quote
Old 05-21-2005, 02:35 PM   #4
SurvCat
mine did this when the TPS went out
SurvCat is offline   Reply With Quote
Old 05-21-2005, 10:10 PM   #5
NCST8TJ
As usual, you guys were dead on! It took two more tries to finally get it seated right, but all's well. Thanks for all your help. By the way, if anyone tells you that changing the manifold gasket on a TJ is easy, they're crazy. The bolts on the underside of the intake manifold are a real PITA to get to. Not engineered very well IMO. Again thanks for all your help
Old 05-21-2005, 11:18 PM   #6
bobsguns
Welcome to the world of a straight 6, sir.
[FONT=Arial Black]I live in a modest home with an immodest array of firearms.[/FONT]
bobsguns is offline   Reply With Quote
Glock Forum
