Need help with suspension alignment - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Need help with suspension alignment
Savvy Aluminum BumpersIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe RuffStuff "I can't go to EJS" Sale!
Unread 02-07-2014, 03:38 PM   #1
Bigjonjeeper777
I have an 04 tj with a rc 6" x flex lift. I have my pinion angles correct and everything else but my coil springs are leaning. Has anyone had this problem before?
Bigjonjeeper777 is offline   Reply With Quote
Unread 02-07-2014, 05:28 PM   #2
tjcj
A 4" rear spring will have a bow in it so a 6" definitely will . To fix it you need to move the upper coil mounting plate towards the rear of the Jeep.
Sent from my XT881 freeze ray gun using JeepForum
Yakima Valley Mountaineers. PNW4WDA[QUOTE=Willu;14149473]Finally you understand that every item sold by currie was hand made by the gods[/QUOTE]
tjcj is offline   Reply With Quote
Unread 02-07-2014, 05:44 PM   #3
Bigjonjeeper777
Ok thanks for the help I'll try it .
Unread 02-07-2014, 06:14 PM   #4
tjcj
You do realize that you have to cut them off and reweld them where you want them.
Unread 02-07-2014, 06:29 PM   #5
Bigjonjeeper777
Haha yea I know I appreciate the heads up tho
