Need help....Stock brakes w/36's - Page 2 - JeepForum.com
post #16 of 31 Old 10-09-2010, 10:47 AM Thread Starter
Farmkid
How much do they cost and where can I order them?
Farmkid is offline
post #17 of 31 Old 10-09-2010, 10:49 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
PM mrblaine, he sells them.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #18 of 31 Old 10-09-2010, 11:01 AM
EricRollerSkate
I have just mounted a set of 36" iroks yesterday. I still have the stock brakes but recently installed new pads and had the rotors turned. What is the best upgrade without dumping a lot of money into it. Can I swap to a different pad and notice a improvement help please.
Super 35 + 36's = awesome!! I beat mine senseless, and I sail over every obstacle with tons of clearance.
Lowered, Dubbed, and Spinning
Why wear a flip flop on your left foot, and a steel toe on the right?
EricRollerSkate is offline
post #19 of 31 Old 10-09-2010, 11:10 AM
garybattles
The pads are $95 shipped. A combo of pads and Centric premium rotors are $225 plus shipping, I believe. PM Mr. Blaine for specifics and to order. Reports from a small group of testers on here say that the Black Magic Pads are equal to or better (most said better) than the yellow stuff and are cheaper to boot. I'm putting mine on tomorrow. And who wouldn't want some magic stuff on their Jeep?
gmb08
garybattles is offline
post #20 of 31 Old 10-09-2010, 11:42 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Please either help me out or don't say anything.
Your stock brakes are NOT strong enough for 36s. period. nothing you do will improve them enough to stop the vehicle adequately enough. You're risking the safety of yourself, and everyone on the road with you.
Either buy smaller tires or buy bigger brakes. You can band-aid it with replacement pads, fancy rotors, fancy brake lines, etc, but the bottom line is the stock brakes are poorly designed.
I run a Vanco 15" wheel Big Brake Kit on 33s and it stops better than bone stock with 30s. And I did it on a budget. I used to run the stock Centric/EBC combo.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #21 of 31 Old 10-09-2010, 11:57 AM
robncar
robncar's Avatar
Originally Posted by robncar View Post
What's "a lot of money" to you for reliable brakes?
Said another way, what's your budget for this project?
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #22 of 31 Old 10-09-2010, 12:00 PM
dling
Just adding, I did rear rubi axle swap and saw no improvement in 4 wheel discs. Was thinking about adding a proportioning valve but everyone I know that has done showed minimal improvements. As always with braking, the front is whats doing the majority of the work.
On another note, I am not having any problem with 35's being difficult to stop. Sometime old spongy lines might make you have a less than responsive pedal. Maybe try upgrading to braided cable brake lines. Don't be afraid to re-bleed either, a little air will make a huge difference.
dling is offline
post #23 of 31 Old 10-09-2010, 12:21 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The stock brakes are perfectly fine for the stock weight of the vehicle and 31" tires. After that, you're on your own.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #24 of 31 Old 10-09-2010, 02:04 PM
lilcobrar
A friend of mine that I wheel with has a 97 on 37" MT/R's with stock brakes and it's been his daily driver rain or shines for the past 2-3 years without any issues.
lilcobrar is offline
post #25 of 31 Old 10-09-2010, 02:15 PM
lumpster
lumpster's Avatar
and when he cant get it stopped you will stop preaching this. Especially when he says, "i knew i should have done something with my brakes, they totally sucked."
I jsut ordered centric premium rotors and Black magic pads from mrblaine, I know that i need a vanco BBK, but im kind of waiting on new knuckles.
lumpster is offline
post #26 of 31 Old 10-09-2010, 02:18 PM
garybattles
Has he had to make any emergency stops? With 32's, stock brakes and ABS, I've had some pretty close calls with idiot drivers that cut in front of me without signaling, make left hand turns at intersections in front of me or run stop lights (California must have 90% of the worst drivers in the country). In some of these circumstances, I've avoided collisions by a matter of inches. And I am a pretty conservative / defensive driver. Would not have avoided many of them with any larger tires. I'm putting on magic pads and Centric rotors tomorrow. I'd say your friend is very lucky or that you guys have much better drivers back there.
gmb08
post #27 of 31 Old 10-09-2010, 02:22 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
So it's your recommendation that anyone with a TJ and the stock system can bolt on 37's and be just fine?
I am Savvy
mrblaine is offline
post #28 of 31 Old 10-09-2010, 02:45 PM
Boodyrider
There IS an intermedaite place between Vanco big brake setup with the new pads and 'good rotors and great pads on the stock setup'.
It's a WJ knuckle conversion, with great pads.
Cost is pretty much the same as Vanco. Only real advantage is in the steering upgrade possibilities that come along with it. HOWEVER... large amounts of fabrication, rersearch, and welding is required.
The only real solution to braking issues with large tires is bigger brakes. Vanco is perhaps the most cost effective approach.
OP... did you seriously think bolting on really big tires and breaking out a sawzall to make them sort of clear was a real solution???
Big tires, lifted Jeeps are WAY more expensive than almost any parts manufacturer is willing to admit. Even the Genright 'complete' kits at around 8 grand don't address issues like steering setups that actually work, or braking issues. They also don't include the nearly 10 grand of axle upgrades needed to effectively use really large tires, like 37+ that are used anywhere but a mall parking lot.
Big tires, done right, are FREAKING EXPENSIVE. Deal with it, or don't go there.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #29 of 31 Old 10-09-2010, 03:48 PM
RubiconRazorbac
RubiconRazorbac's Avatar
This should be a banner on page 1 of the forum.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #30 of 31 Old 10-09-2010, 04:32 PM
hustler905
OK, so front brake upgrades are adequately detailed. I currently have 33" tires with 35" in the future. I have PM'd mrblaine and ordered the Black Magic/Centric combo, and have to say he was a pleasure to deal with and highly recommended.
What can I do about the stock drum brakes on my Dana 35 in the back? Is a new set of shoes and decent adjustment/bleed as good as it gets?
hustler905 is offline
brakes. stock to disks via 8.8 whitie_08 YJ Wrangler Technical Forum 4 11-25-2009 12:36 AM
Stock brakes on TJ need help griff2621 TJ Wrangler Technical Forum 2 10-14-2009 08:31 PM
36's on stock axles Foxwakeboarder TJ Wrangler Technical Forum 28 05-14-2009 08:18 AM
Stock Gearing,Stock Brakes...35's. IH8ROADZ TJ Wrangler Technical Forum 12 04-08-2008 12:17 PM
35's or 36's on stock axels NickMG TJ Wrangler Technical Forum 7 12-10-2002 09:42 PM
