Need help with replacement brake pads and rotors - JeepForum.com
post #1 of 11 Old 07-25-2006, 06:16 PM Thread Starter
bshwckr
I need to do a brake job on my rig and was wondering if anyone had any advice - need replacement brake pads and rotors. OEM worked well but they are pricey. Are there any aftermarket ones that provide equal or better performance like semi-metallic, carbon, ceramic?
I have had problems in the past with some "semi-metallic" aftermarket pads and I would like to avoid performance issues. The jeep is a 2003 TJ.
Any advice for a novice?
Thanks!
bshwckr is offline
post #2 of 11 Old 07-25-2006, 06:19 PM
woody-77
Vulcan FTW
woody-77's Avatar
2007 FSJ Cherokee
I think Jerry recommended a brand of pad to use...can't remember which it was....anyone....anyone?????
Gone but not forgotten: '86 CJ7, '06 Wrangler X, '03 Rubicon, '97 Wrangler, '77 CJ5, '74 CJ5(RIP)...gone and forgotten: 07 JK Sahara Unlimited, '78 CJ5
Thread deleted by Jerry Bransford
Reason: This was beyond human decency... posting about someone's girlfriend is ****ed up.
woody-77 is offline
post #3 of 11 Old 07-25-2006, 06:39 PM
Rule303
I've heard Hawk Pads and powerslot rotors are good. Don't know if you'd want a slotted rotor on an offroad vehicle though.
Rule303 is offline
post #4 of 11 Old 07-25-2006, 06:53 PM
woody-77
Vulcan FTW
woody-77's Avatar
2007 FSJ Cherokee
I wouldn't think you would want to put slotted rotors on a TJ unless you are only going to drive on pavement.
woody-77 is offline
post #5 of 11 Old 07-25-2006, 06:56 PM
JoeyBuck
There is a factory technical service bulliton out on the brake compound on TJ's. See if you can talk your local repair shop out of a copy of it.
Having owned a automotive service center for 25 years now, I would only put factory brake parts on your Jeep.
We have tried various aftermarket pads and they just will not work as well.
JoeyBuck is offline
post #6 of 11 Old 07-25-2006, 06:57 PM
fried_gold
fried_gold's Avatar
Best advice I can give you is to make sure you get the correct rotors. Take the old rotor in and make sure it's exactly the same size as the new one. They changed them and there's about 1/8 inch difference, but the computers aren't always right either. For example, my 2001 uses 2000 model rotors and the "correct" 01 rotors won't work (musta had some leftover 00 axles when they made mine). I like Performance Friction pads and I think that's what Jerry recommends too, or maybe it's someone else.
fried_gold is offline
post #7 of 11 Old 07-25-2006, 07:01 PM
fried_gold
fried_gold's Avatar
You can get all TSBs here: http://www.alldata.com/recall/make
post #8 of 11 Old 07-25-2006, 07:03 PM
gregmondro
gregmondro's Avatar
Slotted are fine
You might have troubles with cross drilled ones (getting mud in them) on an offroad vehicle though. But even then I doubt it.
I'd recommend some Powerstop (about 50 a rotor) or some Powerslot ($189ish for both front rotors) slotted rotors for the front if you just want to upgrade the rotors.
Hawk or Performance Fricton Carbon Metallic pads would compliment these nicely.
- NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
gregmondro is offline
post #9 of 11 Old 07-25-2006, 09:16 PM
daveg13
daveg13's Avatar
'99 Sport
31X10.5-15 BFG AT, some Tuffy boxes, slowly being built.
daveg13 is offline
post #10 of 11 Old 07-25-2006, 09:24 PM
FutureJK
FutureJK's Avatar
x2 on making sure you get the right rotors, i had the same problem, 1/8 of an inch difference
FutureJK is offline
post #11 of 11 Old 07-26-2006, 01:45 AM
Border Dave
Got Sand?
Border Dave's Avatar
Aren't you guys following the Big Brakes thread?
http://www.jeepforum.com/forum/showt...ghlight=brakes
My favorite shops in the Northwest:
Border Dave is offline
YJ Brake Replacement (Pads, Rotors, Drums) - How much? l3it3r YJ Wrangler Technical Forum 15 09-29-2008 10:05 PM
Recommended Brake Rotors & Pads? cvd TJ Wrangler Technical Forum 35 08-19-2008 11:07 PM
Upgrading front brake pads and rotors? 05moabTJ TJ Wrangler Technical Forum 16 06-08-2008 10:26 PM
Brake questions for replacement rotors and pads for TJ's. BlueJ TJ Wrangler Technical Forum 16 07-12-2006 01:24 AM
Brake Pads And Rotors WR4NGLER TJ Wrangler Technical Forum 50 07-23-2004 06:31 PM
