Need Help please... (NSG370 fill and drain plug wrench requirements) - JeepForum.com
post #1 of 15 Old 04-27-2010, 11:59 AM Thread Starter
mouse
I went out got all the stuff to change the fluids in mt TC and Trans and i can't find the wrench to fit the NSG370 drain and fill bolts. can some one please point me in the right direction on the size and where i can get the right tool for the job.
mouse is offline
post #2 of 15 Old 04-27-2010, 12:49 PM
Rubikahn
Rubikahn's Avatar
I picked up 14mm and 17mm hex head sockets. I can't remember which is fill and which is drain, but those are the two sizes I bought when I changed my trans fluid.
OME ZJ/LJ lift, 33" MT MTZ on AR-23 wheels, front and rear JKS trackbars, 1" seat risers, MORE 1" BL and MML, factory Ipod adapter. Light khaki jeep club #72
Rubikahn is offline
post #3 of 15 Old 04-27-2010, 01:12 PM Thread Starter
mouse
Thanks i found them.. In case anyone else needs to know and you can't find them at Sears on line ...
Sorry ment you can find them at Sears..
mouse is offline
post #4 of 15 Old 04-27-2010, 01:57 PM
gtstricky
http://www.sears.com/shc/s/p_10153_1...P?keyword=14mm
http://www.sears.com/shc/s/p_10153_1...P?keyword=17mm
Must reads for new TJ Owners:
gtstricky is offline
post #5 of 15 Old 04-28-2010, 02:38 AM
bojang
You can also get a 14 and 17 mm bolt and nut, tighten them up together, and use that if you have to.
Chris
Freedom from nags, cranks, government, do-gooders, control-freaks and idiots is all that I ask for.
Never trust a lumpy fart.
bojang is offline
post #6 of 15 Old 04-28-2010, 07:26 AM
Night Wolf
Auto zone sells a 3pc hex socket set for about $15 - 2 of the sizes are the 14 and 17mm.
Night Wolf is offline
post #7 of 15 Old 04-28-2010, 07:34 AM
Night Wolf
post #8 of 15 Old 04-28-2010, 07:36 AM
Zen
Slightly off-camber:
If you have come to this thread looking for the info for a Rubi Xfer case. My plugs were 10MM hex. I bought a 7 peice 3/8" drive hex socket set from Wal-Mart.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #9 of 15 Old 04-28-2010, 07:36 AM
Mayfair_Jeeper
Mayfair_Jeeper's Avatar
Anyone know what the 231 TC uses?
2006 Jeep TJ X Modded with toys
2008 Jeep Liberty Sport Stock
1987 Cherokee 4.0 Renix...Build in Process
Mayfair_Jeeper is offline
post #10 of 15 Old 04-28-2010, 07:42 AM
Night Wolf
Torx, iirc T55, just like the sway bar - maybe a T50 tho
post #11 of 15 Old 06-07-2012, 07:27 AM
yellowrubicon
yellowrubicon is offline
post #12 of 15 Old 06-07-2012, 08:55 AM
sethhawk1
My np 231 takes a 10mm hex head. I know this size well cause i had to keep checking on the fluid due to the big crack in the casing.
sethhawk1 is offline
post #13 of 15 Old 06-07-2012, 09:07 AM
chubbena
How are you able to keep the nuts from loosen up when turning anticlockwise?
chubbena is offline
post #14 of 15 Old 06-07-2012, 09:47 AM
flying_bosun
Use two nuts and lock them against eachother, use the bolt head as the key in the plug and turn it all using a wrench on the "middle" nut.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #15 of 15 Old 06-07-2012, 11:26 AM
chubbena
Thanks! I could have saved $15 for the hex key
chubbena is offline
Where is the drain plug and fill plug on manual transmission Mr_E YJ Wrangler Technical Forum 2 07-11-2009 04:26 AM
Drain and Fill Plug??? Supertau TJ Wrangler Technical Forum 1 06-04-2008 05:24 PM
large drain plug and fill plug stu'sjeep TJ Wrangler Technical Forum 4 04-21-2008 09:14 PM
What size wrench for '95 nv231 transfer case fill and drain plugs? Nelliebelle7 YJ Wrangler Technical Forum 20 02-24-2008 02:12 PM
What size allen wrench does the transfer case fill plug take? 61 uni TJ Wrangler Technical Forum 4 07-29-2006 11:37 PM
