Quantcast need help please (manual tranny shifting difficult when cold) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > need help please (manual tranny shifting difficult when cold)
Old 12-18-2007, 09:35 PM   #1
chafalote
i just purchased a 2001 wrangler 2.5 with a 5 speed tranny,i just changed the clutch and components and changed the tranny lub. i live in el paso tx, the temp here does not get to cold. in the mornings i have a litle trouble engaiging the tranny in 2nd and 3rd, after about 15 minutes of driving the problem goes away, im puzzled.
chafalote is offline   Reply With Quote
Old 12-18-2007, 09:47 PM   #2
BradyAds.com
Its the transfer case. It just needs to heat up a bit....Maybe? Mine does that as well, but I attribute it to the cold in Michigan.
[COLOR="Blue"][SIZE="3"][B][url]www.leossportsbar.com/MyJeep.htm[/url][/B][/SIZE]<---relive the build and other Pictures[/COLOR]
[COLOR="Red"][SIZE="4"][I]06tj + 3" rustys package + 33x12.5 Baja Claws[/I][/SIZE][/COLOR]
BradyAds.com is offline   Reply With Quote
Old 12-18-2007, 11:18 PM   #3
chafalote
Thanks, hope both of us can get the problem resolved.
Old 12-18-2007, 11:23 PM   #4
Savvy
Savvy Off Road
Savvy's Avatar
Have you changed the tranny fluid lately? On my 2000, it shifted badly until I changed the fluid.
Email me for the fastest response: gman@savvyoffroad.com
Follow us on Facebook FACEBOOK.COM/SAVVYOFFROAD
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
PM MrBlaine for Black Magic Brakes!
http://www.savvyoffroad.com
2006 LJ Unlimited Black Hole
2005 LJ Test Mule
2003 TJ Project Unrolled
2003 TJ Project Click Here
Savvy is offline   Reply With Quote
Old 12-19-2007, 12:35 PM   #5
Death_Valley_TJ
Old dude
Death_Valley_TJ's Avatar
The transfer case should have little to do with transmission shifting. What lube did you put in the transmission? Some recommend Red Line MT-90. It sounds like the transmission lube is slow to warm up.
Death_Valley_TJ is offline   Reply With Quote
Old 12-19-2007, 01:13 PM   #6
DaOne
Agreed. I would make sure you have the right fluid in the tranny. Royal Purple seems to work pretty good. Also Amsoil...
...Sometimes, the more you see, the less you understand...
I miss my Jeep. On the hunt for a replacement.
DaOne is offline   Reply With Quote
Old 12-19-2007, 02:22 PM   #7
4x4grey88
ROCK WHEELER
4x4grey88's Avatar
Originally Posted by chafalote
i just purchased a 2001 wrangler 2.5 with a 5 speed tranny, I just changed the clutch and components and changed the tranny lube. i live in el Paso Tx. the temp here does not get to cold. in the mornings i have a little trouble engaging the tranny in 2nd and 3rd, after about 15 minutes of driving the problem goes away, I'm puzzled.
Since you just had the clutch changed, try taking it back to the mechanic who changed it and ask him about the alignment for the shifter. the lubrication oil is probably just 90w gear oil and is the same weight that was in prior, so the oil is not it.
___________________________________________
In or Near San Diego, CA? Click Here
Black Jeep Club Member #1016
Senior Member: Jeep Repair Club, San Diego Chapter
4x4grey88 is offline   Reply With Quote
Old 12-19-2007, 02:39 PM   #8
DaOne
I would think that if it was something such as the alignment for the shifter, the problem wouldn't go away after 15 minutes. Just my 2 cents...
Old 12-19-2007, 02:56 PM   #9
Sahara01
I have known several people with shifting issues in their manuals...they changed to Amsoil MTF 5w-30, and the problem went away.
Let me verify what I posted above. I don't want someone to put the wrong fluid in their tranny. I will update and verify asap.
Shortbus Offroad Team #242
sponsored by
www.rockkrawler.com, GOODYEAR TIRES, http://www.browndogoffroad.com/ , Solid Axle Industries, Genright,
Sahara01 is offline   Reply With Quote
Old 12-19-2007, 04:13 PM   #10
Dogman
That's pretty normal for cold mornings. You do want to verify that you have the correct fluid in it though. I can't remember if the 2001 had the AX-5 or the NV series - each require a different fluid.
Dogman is offline   Reply With Quote
Old 12-19-2007, 04:25 PM   #11
06WranglerX
Normal, I have a ford probe i use to drive in the winter and i would have to allow it 10 min to warm up so the fluid wasn't so thick and i could actually get it from N to 1 or 2nd. On really cold days it would sometimes take 15 min, best advise i can give you, park it in the garage if you have access, or allow it 10 min to warm up. so the fluid isnt so thick.
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline   Reply With Quote
Old 12-19-2007, 04:28 PM   #12
Sahara01
NV3550 is what is listed for 2001, 2.5L, and 5 speed.
Ok, I see two different transmissions listed on the Amsoil site. The folks I know used Amsoil MTF 5w-30 in their NV3550's with great success.
Amsoil also show's a EX NV3550 which they recommend MTG 75w-90 fluid.
I'm personally not sure of the difference in the two listings for the transmissions ?
Anybody..if not I will contact Amsoil and find out...
sponsored by
Old 12-19-2007, 10:16 PM   #13
Sahara01
Ok, EX means except the NV3550. it seems they may have used a AX-5 behind the 2.5, so ya have to find out what tranny you have for sure.
http://www.novak-adapt.com/knowledge/nv3550.htm
http://www.novak-adapt.com/knowledge/ax5.htm
sponsored by
Old 12-19-2007, 10:34 PM   #14
djt283
Mine just started shifting pretty rough also now that it's getting cold. I changed the fluid to Royal Purple a couple of days ago based on reviews on this site and it works amazingly well. I doubted it would make a difference but it shifts much smoother and is much quieter. It even eliminated the roughness I had in neutral.
djt283 is offline   Reply With Quote
Old 12-19-2007, 11:30 PM   #15
4x4grey88
ROCK WHEELER
4x4grey88's Avatar
Yes but the mechanic could have not aligned the tranny, linkage, and/or transfer case which might make it difficult to shift.
It did not do it prior to replacing the clutch --did it?
Glock Forum
