need help. Overheated, replaced parts, still overheating - JeepForum.com
post #1 of 16 Old 02-25-2012, 08:09 PM Thread Starter
NICU
overheated on the highway the otherday. while driving notice the heat climb to 260 right after that within seconds trying to get over to the breakdown lane (heavy traffic) my radiator blew. pulled over turned the engine off. got tow home. put in new t-stat (thought that was the problem)new radiator flushed and filled radiator and new cap.burpped the system.
still overheats while driving and have no heat at all . oh ya change the oil too just changed it days before this happend. please help
NICU is offline
post #2 of 16 Old 02-25-2012, 08:33 PM
-ShockWave-
Let it idle for longer in your driveway, to see if there is more air in the system, if that does not work.. disconnect the heater core hoses, try to run a garden hose through the core to check if it is blocked. If it is not blocked inspect water pump.
^^ My complete AC install thread^^
-ShockWave- is offline
post #3 of 16 Old 02-25-2012, 08:43 PM Thread Starter
NICU
i have heat at idle and waterpump shaft was tight
NICU is offline
post #4 of 16 Old 02-26-2012, 07:26 AM Thread Starter
NICU
bump
NICU is offline
post #5 of 16 Old 02-26-2012, 08:23 AM
JealousDad
I bet a lot of people are thinking head gasket
JealousDad is offline
post #6 of 16 Old 02-26-2012, 08:36 AM Thread Starter
NICU
ya i was thinking maybe it was that but oil looked clean and coolent had no oil in either
NICU is offline
post #7 of 16 Old 02-26-2012, 08:43 AM
JPNinPA
So you have heat when idling but not driving?
No heat could be air in the system or a blocked core as stated above.
Could be the fins rotted off the pump impeller.
Could be the spring is gone in the lower radiator hose allowing it to collapse while driving.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #8 of 16 Old 02-26-2012, 08:45 AM
chainbrain2002
only real thing that can blow a rad is a catastrophic head gasket leak at high speed. it caused the coolant chambers to severely over pressurize causing the tank to pop. looks like its time to do a head gasket job. oh and when you have the head off do yourself a favor and take it to a machine shop and have them magnaflux it to check for cracks.
chainbrain2002 is offline
post #9 of 16 Old 02-26-2012, 09:48 AM Thread Starter
NICU
spring is good on lower hose and it still runs great. might just replace the water pump it a few years old.if its a head gasket problem and the head is cracked what should i do?
NICU is offline
post #10 of 16 Old 02-26-2012, 10:28 AM
JPNinPA
Here are some things you could check for a cracked head.
When cold open your radiator cap then start the engine. When it reaches temp and the thermo opens you might see a continuous stream of small bubbles coming out.
Check your exhaust. If it looks like a continuous white smoke(steam) it's likely you have a head gasket issue.
Compression tests can show leaking head gaskets.
JPNinPA is offline
post #11 of 16 Old 02-26-2012, 10:49 AM
chainbrain2002
I agree with that. Also after the engine gets fully warmed up with rad cap on. Go to exhaust and sniff the fumes from it. If it smells sweet other then regular same thing. If so take to shop and have them perform a cylinder leakdown test. That will show where the leakage is coming from. If this is the case. Head gasket time. If head is cracked. Replace with non 301 head.
Originally Posted by mike481 View Post
My jeep is magic...it can make all my money disappear.:eek:
post #12 of 16 Old 02-26-2012, 01:53 PM Thread Starter
NICU
ok no bubbles when cap off and running up to temp and no white smoke coming out of exhaust
NICU is offline
post #13 of 16 Old 02-27-2012, 02:55 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Not really, 260 liquid water is under tremendous pressure. It will easily split these plastic tank rads.
Are you getting coolant flow at the rad?
ratmonkey is offline
post #14 of 16 Old 02-27-2012, 04:41 AM
kaiter
kaiter is offline
post #15 of 16 Old 03-17-2012, 10:13 PM Thread Starter
NICU
Just changed out the water pump and clutch fan that should do the trick because I thought the pump was good but it turned out it was no good. I just got back from south Carolina so I had no time till today to mess around with it. That's for all the help everyone
NICU is offline
Replaced parts - what to do with them? E-95 Wrangler General Discussion 6 02-14-2012 12:51 AM
Need To pump Brakes to STop, And just replaced a lot of brake parts crazyquadder YJ Wrangler Technical Forum 13 04-14-2010 06:32 PM
Replaced blower, replaced resistor... still fan doesn't work Levin2000 TJ Wrangler Technical Forum 1 12-19-2009 04:47 PM
Overheating issue - suggestions before I throw parts & money at it? Oman Jeep TJ Wrangler Technical Forum 65 05-16-2008 08:02 PM
running rich/ replaced parts and my codes wwiihistory YJ Wrangler Technical Forum 10 08-03-2006 10:14 PM
