Need help with over heating problem any ideas - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Need help with over heating problem any ideas
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenRight Offroad at CCOR! 706-207-4140Ring & Pinion's, Lockers, 4340 Axles, Install Kits, Ba
Unread 08-22-2011, 01:50 PM   #1
spune1
All right guys i need some help i have 1997 wrangler 4cyl and i had to replace thermostat because it would randomly over heat now that ive replaced it it still over heats like crazy i hope someone will no how to fix it
spune1 is offline   Reply With Quote
Unread 08-22-2011, 01:53 PM   #2
JWebber
Clogged radiator, or low on coolent. Dirty nasty coolent which can cause clogged radiator etc.. If rad is clogged then most likely the heater core is too. So be sure to flush the whole system, refill with 50/50 prestone coolent and see if that helps. If not then new radiator is in order. And buy a new raditor cap!
JWebber is offline   Reply With Quote
Unread 08-22-2011, 05:50 PM   #3
gmiller0737
Not real common but I have saw a few water pump impellers either corroded away or slipping on the shaft,Is the fan working properly?
gmiller0737 is offline   Reply With Quote
Unread 08-22-2011, 06:41 PM   #4
chmo
I was not OVERheating, but my scangauge was telling me 230+ degrees under load in hot weather and I could smell coolant from time to time. Today in the workshop they diagnosed "bad water pump" after showing me some white residue from coolant splash on the pulley right above the water pump pulley.
The small leak was just enough to let pressurized coolant escape in very small quantities, causing the engine to heat up. (similar to a bad rad cap)
very subtle but bad enough for a reliable cooling ... I am glad I caught it early
(now VERY curious how the water temps and the auto tranny temps will behave once I get my baby back)
(btw ... I hate that fake temp gauge in newer TJs ... it stays at 210 or slightly above no matter what ... until it is too late and you overheat and blow a gasket or warp a head )
"The more I know, the more I realize how much I don't know"
my LS1 swap build thread
THE cheap progressive bump stop solution
chmo is offline   Reply With Quote
Unread 08-22-2011, 07:05 PM   #5
chris142
I wouldn't use Prestone coolant. Prestone is a Dexclone and contains sodium 2-ethyl hexanoate just like Dexcool. I do not recomend Dexcool in your Jeep.
http://www.netbug.net/blogmichael/?p=107
http://www.consumeraffairs.com/autom...m_dexcool.html
http://search.aol.com/aol/search?que...yword_rollover
http://www.leftlanenews.com/old-gm-s...ool-owners.htm
http://www.stuevesiegel.com/CM/Resul...ON-LAWSUIT.asp
chris142 is offline   Reply With Quote
Unread 08-22-2011, 07:25 PM   #6
JPNinPA
Welcome to the board
When you say like crazy . More than before??
Start simple. Fill the system and be sure to Burp the air out.
Note what your temp gauge is when you start to overheat.
What kind of thermo. Some fail right out of the box.
What Temp Thermo?
Did you replace the radiator cap? 18PSI??
When you changed the thermo did you flush the system of just change and refill?
Is it overheating if you just idle or is it at highway speeds...???
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline   Reply With Quote
