Need help with O2 Sensor codes - JeepForum.com
post #1 of 4 Old 07-15-2010, 07:25 AM Thread Starter
xlch
I replaced my bank 2 sensor 1 after getting a code PO153 and it has been fine for about 2 weeks and approx 3 tanks of gas, last night I got a PO152 which is for high voltage on the same sensor. I got the O2 sensor from the dealer is it possible that it was a bad one or should I be looking for something else and if so what?
Tanks do well at crossing ditches and running stuff over but other than that a Jeep will get you anywhere a tank will and more.
Now the tank might get beter gas milage but that is a different story.
xlch is offline
post #2 of 4 Old 07-15-2010, 10:30 AM
Sundowner
Could be a short in the wires or the connector. Check that first. If you can't find anything, check the output of the sensor with a multimeter.
Sundowner is offline
post #3 of 4 Old 07-15-2010, 10:34 AM Thread Starter
xlch
The Jeep is an 06 and only has 34K on it, I did check all the wiring when I repalced it about 2 weeks ago and everything looked like new. I have a multimeter so how do you check the sensor? And what should the readings be?
xlch is offline
post #4 of 4 Old 07-15-2010, 10:49 AM
Sundowner
OXYGEN SENSORS
p0153 , p0152 , o2 sensor , sensor , bad , replace , replacement
What exactly does this (sensor codes) mean???? 00CHRIS TJ Wrangler Technical Forum 8 02-21-2010 05:29 PM
O2 sensor/codes question txflood3 TJ Wrangler Technical Forum 10 09-28-2008 07:18 PM
Throwing O2 sensor codes Giviner TJ Wrangler Technical Forum 3 01-19-2008 04:35 PM
02 Sensor codes Gabe TJ Wrangler Technical Forum 4 09-01-2007 09:02 AM
Engine Codes...O2 Sensor? UMDJeepTJ TJ Wrangler Technical Forum 2 05-16-2004 01:49 PM
