Need help. No start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Need help. No start
Engo winches available at www.rockridge4wd.com! Free shippTJ Dana 60 - BOLT IN REARSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREE
Unread 07-25-2012, 12:52 AM   #1
Harvey5678
Need help. No start
01 TJ 4.0 5 speed... So here's what happened. I pulled the jeep up to the garage this morning to pull the doors and top off before work...everything was fine. Shut it off did what I had to do and now it won't start, won't even try. And I have no lights anywhere. The jeep is completely dead!
Harvey5678 is offline   Reply With Quote
Unread 07-25-2012, 01:13 AM   #2
frenchy206
frenchy206's Avatar
It takes around 15 min for your dome lights to go off when a door is left open, or in this case, doors removed. There are 4 lights, usually. One on each side, down by your feet, as well as the two up top next to your speakers.
I would guess that your battery was a bit weak, and the lights being on for that much time either ran the battery down or, now I'm not sure if our Jeeps have this, but in some cars they have a voltage monitor, and if there is a constant drain, the system shuts down.
I've had this happen once when a friend pulled the key out but didn't turn the ignition off all the way. (my key can be pulled out even when driving).
Try unplugging the battery terminals, then re connecting them. That should solve your issue...hopefully.
03 TJ Rubicon
frenchy206 is offline   Reply With Quote
Unread 07-25-2012, 01:18 AM   #3
Harvey5678
Thank you I'll try that after work today. Also I have the fuse pulled for my dome lights. All the lights were bright when I pulled it up but when I tried to restart there was nothing
Unread 07-25-2012, 01:11 PM   #4
Harvey5678
Took both terminals off cleaned them good and it started right up! Thank you again
Unread 07-25-2012, 04:15 PM   #5
frenchy206
frenchy206's Avatar
Glad it worked.
03 TJ Rubicon
