Need help with my TJ when trying to 4wd - JeepForum.com
post #1 of 5 Old 06-07-2012, 11:06 PM Thread Starter
2000TJWithPlow
when i try to go from 2h to 4h it keeps slipping and makes a horrible sound. Anyone else have this problem and howd you fix it?
2000TJWithPlow is offline
post #2 of 5 Old 06-08-2012, 11:15 AM
Fingers302
Do you have a body lift? You may need to re-adjust your linkage under the tub. Or buy a Novak and just replace it.
Fingers
06 LJ Rubicon, not stock
83 CJ 7, all stock
84 CJ7, dang near stock - Daily Driver!
Fingers302 is offline
post #3 of 5 Old 06-08-2012, 11:23 AM Thread Starter
2000TJWithPlow
yeah i have a body lift and the linkage is kinda messed up also so if we fixed one itll fix the other?
post #4 of 5 Old 06-08-2012, 11:54 AM
roosr
There is a set-screw on the transfer case side of the linkage. Place the linkage in 4LO after loosening that bolt. Make sure the transfer case is in 4LO. Then tighten the nut. That SHOULD get your issue resolved. Had a similar issue when putting on a transfer case drop kit. You MAY need to get a bracket that lowers the ball-joint style connection for the linkage mount that is on the driverside of the transmission well. You'll see what I'm talking about when you are under the jeep. but you might be able to get away with just an adjustment.
roosr is offline
post #5 of 5 Old 06-08-2012, 10:35 PM Thread Starter
2000TJWithPlow
thanks a lot i will try that and hope it works
4x4 , problem , slipping
