Need Help Identifying My Lift with Pictures - Page 2 - JeepForum.com
post #16 of 23 Old 02-21-2011, 07:32 AM Thread Starter
dayriesw
dayriesw's Avatar
1987 MJ Comanche
So, I ordered the parts I thought I need from the currie correct lync kit. They ended up being to big to fit.
I still need help to figure out if the steering system is a currie or not. I measured the tie rod thickness. My tie rod is 1.25" outer diameter. Is there anything else that I can measure to help fellow jeepforum member help me figure out this steering?
The two pieces that I need are the "end" that connects to the driver side tire and the "end" that connects to the pitman arm. see pictures 2 and 3 below.
more pics
Also, I am looking for a pitman arm, but none of the local oriellys, autozone, etc have them. Where did you get your replacement? The alignment shop said that the teeth were ground down.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #17 of 23 Old 02-21-2011, 08:19 AM
bairy
That is a clayton belly skid.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #18 of 23 Old 02-22-2011, 05:30 PM
wushaw
Rockin jeep
wushaw's Avatar
more pics
The teeth were ground down??? Did they take the pitman arm off to verify this? And their splines, if they called them teeth you may want to look for another ft. end man.
wushaw is offline
post #19 of 23 Old 02-22-2011, 05:42 PM
xplodn
That looks just like the Currie Drag link, but the tie rod appears to be different. Isn't there a few other companies making the same steering upgrade? Might be more cost effective to just buy a new kit, either Currie or a crossover kit.
As for the ends, it does look like they left the shipping boots on and either cut them or the wore away?
xplodn is offline
post #20 of 23 Old 02-22-2011, 06:02 PM
alextremetj
alextremetj's Avatar
The tie rod appears to be a Rustys unit.
alextremetj is offline
post #21 of 23 Old 02-23-2011, 01:39 PM
danb303
YEP!!!!
looks just like the one I installed on my Rubicon last night. It that's the case then you can get the replacement end from any parts store. Look on Rusy's web page they give you the part number.
danb303 is offline
post #22 of 23 Old 02-23-2011, 01:43 PM
danb303
The replacement part # for the tie-rod ends is:
#52005740 / MOOG part # ES3095R (Right Hand)
#52005741 / MOOG part # ES3094L (Left Hand).
http://rustysoffroad.com/mm5/merchan...egory_Code=ste
danb303 is offline
post #23 of 23 Old 02-23-2011, 01:56 PM
bbuske
Also, why are you paying for an alignment on a TJ? Do a search here or look at Stu's website. In reality all you can do is Toe in to like 1/8" .. there is really no other adjustments.. DS angle trumps caster (or is it camber)..
Originally Posted by Robert J. yates View Post
Now don't be bringing logic into this
Looking to Buy Full Doors and a HardTop near Northern California, PM me if you have them for sale or have a lead on some
bbuske is offline
Need help identifying lift. jarom TJ Wrangler Technical Forum 2 07-12-2010 02:10 PM
Help Identifying a lift?? FlyguyTKI JK Wrangler Technical Forum 11 05-14-2009 12:25 PM
Help Identifying Part (Pictures Inside) digitalcox TJ Wrangler Technical Forum 5 06-06-2008 09:35 PM
Need help identifying lift kit anderob YJ Wrangler Technical Forum 1 08-21-2007 05:57 PM
Help identifying sensor and some random questions... 89 YJ 2.5L - Pictures Included Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-15-2006 07:41 AM
