need help with gearing. - JeepForum.com
post #1 of 6 Old 06-13-2011, 08:45 PM Thread Starter
Brodie720
i have a stock 04 tj.. with dana 35s my gearing is 3.07 my thoughts are as follows. for the build: 3in suspension and 32's for tires it is a must to regear it is my d/d still and highway is still part of my drive.. i dont want to lose all of 5 gear. and i was thinking of 4.56.. if it was a must..
Brodie720 is offline
post #2 of 6 Old 06-13-2011, 09:00 PM
141
[QUOTE=Brodie720;11702483]i have a stock 04 tj.. with dana 35s my gearing is 3.07 my thoughts are as follows. for the build: 3in suspension and 32's for tires it is a must to regear it is my d/d still and highway is still part of my drive.. i dont want to lose all of 5 gear. and i was thinking of 4.56.. if it was a must..[/QUOTE
4.56 will work great. If you plan on going bigger eventually, I would get 4.88's. I'm driving on them now and I'm hitting like 3,100 rpms doing 70ish. I can pull long grades in 5th and go up some pretty steep hils in 4th, where I was downshifting to 3rd. You will have to get new carriers to go with anything lower than 3.73's I believe. You can get open ones fairly cheap, or spend a couple hundred more and get a limited slip or Aussie locker. Depends on what kind of driving you want to do.
141 is offline
post #3 of 6 Old 06-13-2011, 09:08 PM Thread Starter
Brodie720
im not lookin to be crawling rocks or anything huge.. but trails would be nice and of course to work and back lol is it a job that takes some special tools and a very exp person, to do or a case of beer and get in to hur.. thanks alot for the info.
post #4 of 6 Old 06-13-2011, 09:10 PM
flying_bosun
http://www.grimmjeeper.com/gears.html I'd say 4.10s for 32s, but I can't tell my *** from a hole in the ground
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #5 of 6 Old 06-13-2011, 09:17 PM
robncar
robncar's Avatar
I'd also go with 4.56 but you might as well step up to 33's too.
Just for clarity, an Aussie is not a carrier but "lunch box" locker that replaces the internals of a carrier. Great for the front.
I'd recommend paying a pro to install gears. Someone with a good reputation and does them everyday for a living.
Sent from my DROID2 using JeepForum
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #6 of 6 Old 06-14-2011, 06:06 AM Thread Starter
Brodie720
thanks alot for your help.
gearing??? :( 03rubicon35s TJ Wrangler Technical Forum 10 03-08-2009 09:53 PM
Need some help with gearing... gunnerharley TJ Wrangler Technical Forum 2 03-04-2009 07:10 PM
Swapping a 30/35 with 3.07 gearing for a 30/35 with 4.10 gearing...? Erik T. TJ Wrangler Technical Forum 13 10-02-2006 09:58 PM
Gearing with 33s mferrari YJ Wrangler Technical Forum 10 12-13-2005 07:33 PM
Gearing in differential and gearing in t-case, little help ... farinspace TJ Wrangler Technical Forum 6 03-06-2005 02:31 PM
