Need help finding relay/plug part number - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Need help finding relay/plug part number
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 01-25-2015, 01:21 PM   #1
bozsh132
Hey guys need some assistance finding the name or part number of this plug/relay. The back of the plug has a number 83159.
I have a 1997 2.5L manual trans.
I recently did a motor swap and having trouble getting it back running so when looking everything over I came across this plug/relay...
I was taking it off to clean corrosion etc. because I noticed how bad the mounting tab itself was (where you would bolt it to the fender).
It is located on the right side(passenger) fender near the battery and under the PDC. (its wires come from PDC)
On a side note
I also broke off the red wire on the harness side when pulling the plug apart, any good ideas to fix this? was thinking of getting the pin out and soldering it back on. (more so worried about the relay/plug part #.
jeep-tj-relay-pic1.jpg   jeep-tj-relay-pic2.jpg   jeep-tj-relay-pic4.jpg   jeep-tj-relay-pic5.jpg
bozsh132 is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 01:49 PM   #2
2jhanna
Most car parts stores will have this. See link below.
http://www.amazon.com/Auto-Truck-Rel.../dp/B007JPPQH6
jhanna
denton county, tx
2jhanna is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 02:20 PM   #3
bozsh132
thanks for the quick reply...
just a few questions:
do you know if this is the correct application (40AMP) for my 2.5L TJ?
Also, the OEM has a metal tab for mounting, I thought it might be grounded, is that the case?
If so - will the plastic mounting tab on the replacement relay affect anything?
Thanks again
Unread 01-25-2015, 02:27 PM   #4
JeepnBlake
It's not grounded through the mounting tab so it's a non issue.
-Blake-
Build Thread: http://www.jeepforum.com/forum/f22/j...thread-985907/
Dad's Build Thread: http://www.jeepforum.com/forum/f22/d...build-1474170/
OEM Fog Light Connectors, Conversions, and Extension Info:http://www.jeepforum.com/forum/f20/o...ngler-1008928/
JeepnBlake is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 04:54 PM   #5
bozsh132
okay gotcha, any idea on the amperage ?
i am unable to find this relay in any of the documentation i've come across
Unread 01-25-2015, 06:06 PM   #6
DanielW
Junior Member
Does this help? If this is correct diagram which component is it?
DanielW is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 06:33 PM   #7
2jhanna
If any thing, the 40amp is more than you need, but that won't hurt. More is better, in the case of a switch or relay, but not for a fuse.
Just splice in the socket "pigtail harness", doing one wire at a time, from the old socket to the new socket. You can solder/heat shrink, or use crimp on butt connectors
jhanna
denton county, tx
Unread 01-25-2015, 07:42 PM   #8
bozsh132
no that only shows the relays inside the PDC, if you look at my 3rd and 4th pictures in the original post it shows the location of the plug (the wires of this plug come out of the PDC and lead to various places such as battery/chassis/block grounds and power.)
Okay wasn't 100% sure if too high amperage was a problem, or if the 40a is sufficient since I can't find the specs of the OEM relay,
Unread 01-25-2015, 07:57 PM   #9
2jhanna
From my experience, I have never seen one of the black"cube style" higher than 40amp.
jhanna
denton county, tx
Unread 01-26-2015, 04:57 AM   #10
Jonny Jeep
Jonny Jeep's Avatar
It's not OEM so you won't find it in the factory service manuals or part lists. Perhaps it's for an aftermarket alarm or immobiliser. If there isn't one fitted that you know of you could reinstate the original wiring.
Online factory service manuals and parts lists - http://www.jeep4x4center.com/knowledge-base/index.htm
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 09:10 AM   #11
bozsh132
okay thank you.
well that makes sense... maybe I will look into reinstating the original set up once I get it back running correctly, don't want to throw any other possible causes at it right now..
Unread 01-26-2015, 10:00 AM   #12
mrblaine
Wizard of Brakes
mrblaine's Avatar
They make the basic Bosch pattern relay in both 60 and 70 amp versions with 4 terminals, two of which are larger for the higher current loads.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 04:21 PM   #13
Jonny Jeep
Jonny Jeep's Avatar
Can you follow the wires switched by the relay and find the colour of the wire it goes to. If you do that I'll have a look and see what circuit the relay on.
Sent from my B15 using JeepForum
Unread 01-27-2015, 05:25 PM   #14
bozsh132
this drawing may be a little confusing but i can probably do better this weekend ...
there are 3 wires goin underneath the PDC that aren't visible until I take it all apart,
--theres a smaller gauge wire running to the starter,
--then 2 wires (one black one blue) heading toward this mystery relay/plug...
the yellow wire leads into the firewall, cant tell where it comes out under the dash until the weekend as well (im guessing this yellow wire is why the relay exists)
Unread Yesterday, 07:24 AM   #15
DanielW
Junior Member
Does this help any?
