Quantcast Need help finding a lug nut key! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Need help finding a lug nut key!
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 12-07-2008, 05:33 PM   #1
pigpen8304
This could be a better issue to put in the wheel and tire forum, but I needed an answer sooner than later. So somewhere down the road between wheeling and working on my jeep, I have lost my lug nut key. Which really sucks, because today I was getting ready to put on new brake pads and rotors. Anyone know where I can find a replacement? I know about all of the other opitions to break it off and what not, but I would really like to find a replacement if at all possible. Searched the forum all day to find an answer, but no luck. Any help be much appreciated. Thanks in advance.
2003 Jeep Wrangler Rubicon/ 4.0L/ 5spd./ Dana 44 front and rear/ 4.5" RE LA/ 35x12.50 Goodyear MTR's/ stock front locker, Arb rear locker/ 33 spline Alloy USA chromolly axles rear/ Alloy USA 4.56 gears/ Arb bull bar/ Warn 9.5 ti/ Optima blue top/ Safari snorkel/ Rocker guards, diff guards, Garvin rear swing tire carrier/Currie antirock/ Currie HD tie rod kit/ etc.
pigpen8304 is offline   Reply With Quote
Old 12-07-2008, 05:42 PM   #2
roadking
roadking's Avatar
When you bought the wheel locks they should have come with a serial number from the manufacturer that will let you order replacements.
Gotten Savvy! Awaiting Tummy Tuck ;-)
http://video.google.com:80/videoplay?docid=-2512249746173560379&pr=goog-sl
65 million firearms owners killed no one yesterday - Assault is a behavior, not a device.
roadking is offline   Reply With Quote
Old 12-07-2008, 05:50 PM   #3
'51plymouth
1995 XJ Cherokee
^Yep, what he said.^ That's your only choice, besides hammering on an impact socket and replacing them with new locks or lugnuts.
'51plymouth is offline   Reply With Quote
Old 12-07-2008, 05:58 PM   #4
rubidriver
rubidriver's Avatar
That is not your only source.
If you have the SN, go ahead and call McGaurd and they will send you one.
If you were like me and didnt have the SN, take 3 good pics, as I did, and get a hold of a rep there and they will let you send it to their email. They got it right the first time with me, I was really impressed. Here is the picture I sent which is high quality because my mom is a photographer so it worked out great.
Heres what I sent them
2005 Black Rubicon - OME 933/942 - OME N66/N67 - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16 MTZ
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote
Old 12-07-2008, 06:20 PM   #5
pigpen8304
Thanks for all the help so far. And I didn't buy these wheels locks, they came with the wheels when I got them. So unfortunatley I do not have the serial number.
Old 12-07-2008, 06:29 PM   #6
rubidriver
rubidriver's Avatar
I thought these were stock wheel locks, are you saying they arent?
If so what brand are they?
Old 12-07-2008, 06:36 PM   #7
Bill C
take a look in the glove box.........McGuard gives a serial # sticker with their locks. That's where I put mine.
As an electrician I always advise:
"Remember, it's only a shock if you don't expect it" :-)
Bill C is offline   Reply With Quote
Old 12-07-2008, 06:51 PM   #8
Jacon
I went through a similar situation as this with a Honda CRV we used to have. I lost the key and didn't want to take it on long trips since I would not be able to change a tire if we had a flat. They were factory locks and the hassle to go through Honda and get a new key plus the cost was not worth it. I went to a tire shop and they tac-welded old lug nuts on them and got them off for $10 each. Not sure if it was the best way, or the cheapest, but it fixed my problem the quickest and easiest way for me.
Jacob
Jacob
Jacon is offline   Reply With Quote
Old 12-07-2008, 06:57 PM   #9
pigpen8304
They might be stock wheel locks. I'm not real sure. I think that I'm just going to break them off and get a reagular set of lug nuts. This has turned out to be a real headache. Thanks for all the help once again.
Old 12-07-2008, 06:58 PM   #10
Canfourjeep
Lug nuts
Easiest way is to drive a socket on the existing lug nuts with a BFH and just screw them off. Then buy a new set cheaper than most other ways
Canfourjeep is offline   Reply With Quote
Old 12-07-2008, 07:05 PM   #11
Jeepster83
and be sure to use a Craftsman socket. get a replacement for free from Sears.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Currently seeking employment in the automotive field or fabrication. PM me for resume and list of qualifications.
Jeepster83 is offline   Reply With Quote
Old 12-07-2008, 07:09 PM   #12
pigpen8304
Yep...pretty sure thats what I'm going to end up doing.
Old 12-07-2008, 07:12 PM   #13
frontlinedude
if you are out of other options, Big Brand Tire was able to get a damaged one of mine off for $10 even. They are used to those kind of things and they have the right tools, although they were worried about damaging the centercap, but it didn't.
'97 BLACK TJ Sport
4.0L 5 speed Man.
4in lift
35"x13.5 Toyo Open Country M/T
Herculined
frontlinedude is offline   Reply With Quote
Old 12-07-2008, 07:14 PM   #14
medDOyj
i know snap-on makes a tool to take off wheel locks. i don't know if your local auto parts store would have one you could borrow or not.
pictures 1989 yj Sahara 258 6cyl auto <-- updated occasionally
a build thread awaits....
medDOyj is offline   Reply With Quote
Old 12-07-2008, 07:16 PM   #15
OldFatGuy
There's a special tool to remove them that's not too expensive.
I have the Snap-On equivalent of this kit and it works really well. If you don't want to buy it, call a couple of tire stores. Most of them probably have the tools and would do it for you fairly cheap.
*EDIT*
The last couple of posters pretty much said the same thing while I was typing.
OldFatGuy is offline   Reply With Quote
Glock Forum
