need help fast! clutch/master cylinder no clutch! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > need help fast! clutch/master cylinder no clutch!
Jeep Restorations, Mild to Wild! CCORBead Lock Wheels! Raceline, Trail Ready, & Trail-GearVisit our new Jeep Store in Georgia
Unread 11-30-2005, 04:45 PM   #1
miguelitojeep97
ok so it started out being really hard to put into gear. to the point of where in the morning i couldnt get it in gear while the jeep was running, at all. so got it towed home. read a lot of posts on here about master cylinders going out so that sounded right. so i just installed the new one, but do i need to bleed it? i still have just about no resistance at all. i took off the slave and it looks mucky, but when i depress the clutch i still get a lil movement out of it. whats the deal guys? cant get this damn clutch to work at all. if anyone has pictures or a write up on this i would be very happy. i cant stand having my jeep sitting in front of my house! please any info!!
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more...
miguelitojeep97 is offline   Reply With Quote
Unread 11-30-2005, 07:43 PM   #2
Hunter9
Sounds like you may actually have a bad slave cyl. You say it was all mucky (I guess it was leaking??) and it has a little movement? It may be bypassing under load and only working when you have it off and not under load. Just a thought.
[CENTER][COLOR=White]97 Sport [/COLOR] 4.0l Auto D30/D35
RE 3.5 SF, 1" BL, 1" MML, 285/75/16 (33") MTRs, 16x8 MT Classic Locks, 4.10 gears, Lockrite Front, Warn Front and Rear Bumper w/ Tire Carrier, Warn Diff Skids, Rock-it Man Rockers, Jeeperman Front Hoop, M8000, A to Z winch mount, Hella 500s, H4 Conversion
[COLOR="Red"]Former 3.07 Gears Club Member #1[/CENTER][/COLOR]
Hunter9 is offline   Reply With Quote
Unread 11-30-2005, 08:54 PM   #3
miguelitojeep97
thanks for the reply i was hoping for more feedback from more people, but after more research i just ended up ordering a slavcylinder. wish i woulda just done that to begin with, but im low on cash. thanks again for the feedback. hope thats the problem and hope i can get it bled.
Unread 12-01-2005, 01:53 AM   #4
badoosh27
its always a good idea to change both at once. also, if it starts to gets really easy to push in, fill the resevoir with brake fluid. its not perminant, but it will get you home. i have yet to need to change mine out so i cant really help with it. good luck.
badoosh27 is offline   Reply With Quote
