Need help, Boston area! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Need help, Boston area!
Engo winches available at www.rockridge4wd.com! Free shippTJ Dana 60 - BOLT IN REARSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREE
Unread 01-18-2006, 03:10 PM   #1
TJ_with_Tusks
I'm picking up a new set of axles for my TJ. I am a college student in Boston, renting an apt. with no garage. I need a place to swap axles. I have all my own tools. Is anyone in the Boston area willing to let me put my Jeep in their garage to swap axles. It would most likely be over a weekend.
04' Columbia TJ
33" BFG AT's, OME HD lift, front airbag suspension, teralow 4:1 kit & supershort shaft kit, TW CV shaft, 4.10 gears, JKS body lift, track bars and quicker disconects, Warn 9.5ti, warn front bumper, garvin wilderness rack, and solid cast aluminum tusks,
TJ_with_Tusks is offline   Reply With Quote
Unread 01-18-2006, 03:21 PM   #2
base shakers
where are you in boston? i also rent in somerville (davis square), but the landlord lets me park my jeep in the garage. it is a small, two-car garage, but it may be enough space for you. i have access to both bays, (though one is half full of stuff.) if you want to come by sometime and have a look to see if it's enough space, you are more then welcome to!
'05 Unlimited, 3"+ AEV/Frankenlift, 1.25" JKS BL + MML
35X12.5 Toyo M/Ts on 16" Allied beadlocks
HPD44 with RCVs and elocker, HPD60 with ARB
4-speed Atlas
lots of armor, bunch of other goodies
Baystate Jeepers member
base shakers is offline   Reply With Quote
Unread 01-18-2006, 04:55 PM   #3
TJ_with_Tusks
I live on Tremont St. near Northeastern. How far is that from you?
04' Columbia TJ
Unread 01-18-2006, 05:56 PM   #4
base shakers
15 min drive. i'm right near tufts.
4-speed Atlas
Unread 01-18-2006, 06:53 PM   #5
Rocky529
Jeep
Rocky529's Avatar
Do you go to Northeastern?
Btw I'm in Arlington.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Unread 01-18-2006, 08:22 PM   #6
TJ_with_Tusks
I actually go to Wentworth. I'm an Electromechanical Engineering student. I dont have the axles yet, but I will let you guys know when I get them. Thanks in advance for the offer, I appreciate it.
04' Columbia TJ
