Need Gear upgrade/Axle Swap Advice - Page 3 - JeepForum.com
post #31 of 34 Old 07-21-2010, 09:50 PM
2003X
Its ok. The used pads and rotors I got were in excellent shape. I can probably get another year maybe 2 out of them.
My Build
2003X is offline
post #32 of 34 Old 07-22-2010, 06:48 AM
freeskier93
That's good to know because when I do my axle swap those are the axles I want. Wasn't sure of the quality of the used parts though.
freeskier93 is offline
post #33 of 34 Old 07-22-2010, 09:30 AM
cmyTJ
Originally Posted by Davecore555 View Post
Wow so on top of the cost of the HP D30 & Ford 8.8, I'm going to have to add a SYE, CV DS, and Adjustable Upper Control Arms??? Just to run 35's is getting $$$$.
I wonder how the uppers and all will affect my R.E. 3.5 lift??
I have the RE 3.5" with upper adjustable arms and the setup is great.
I am hoping to order my locked 8.8 from ECGS soon but debating on the HP30. They are local for me so no shipping. I currently run 33's and plan to go larger with my next set. I am also doing the SYE and CV DS with the rear swap. I am doing a slow build trying to get things as I can. Not optimal, but works. I will probably regear and upgrade front axle when shifting to larger tires.
cmyTJ is offline
post #34 of 34 Old 07-22-2010, 08:23 PM Thread Starter
Davecore555
Yeah, seem that is what I'll end up doing for now building slow. Just put on some new BFG A/T KOs today, so I'll probably start saving up for the whole swap.
Davecore555 is offline
axles , gears , tire size
Axle or Gear Upgrade photoboy74 YJ Wrangler Technical Forum 7 05-12-2010 02:41 PM
axle/gear upgrade advice... gunnerharley TJ Wrangler Technical Forum 2 11-08-2009 10:46 PM
LJ axle upgrade and re-gear questions gcally TJ Wrangler Technical Forum 19 01-28-2009 06:02 PM
Axle/Gear Upgrade Options dpoelstra TJ Wrangler Technical Forum 14 08-11-2006 10:15 AM
More axle?s Upgrade D35 or swap it out? Jeep14636 TJ Wrangler Technical Forum 29 01-15-2005 09:12 AM
