Need Gear upgrade/Axle Swap Advice - Page 2 - JeepForum.com
post #16 of 34 Old 07-18-2010, 12:16 PM
2003X
the 94 and up Mustangs are 5 on 4.5. Earlier ones are 4 lug. I think they are a little shorter then the explorer. You can upgrade the shafts because I believe they came 27. Im going to say get on out of a explorer to save yourself the trouble. You will also need to weld the brackets on the 8.8 and have them perfect.
For the time and money you are going to sink into the 8.8 to get it right, just order it done and have it shipped to your house.
I am using my stock ds right now. No sye or adj uppers either. But yes, you will need them as I do. I am just trying to put some cash away to get all three.
Complete Ford 8.8" Rear Axle Assembly Jeep TJ Ready to Bolt In Axle Swap
My Build
2003X is offline
post #17 of 34 Old 07-18-2010, 12:17 PM Thread Starter
Davecore555
Also I was thinking of going for the 4.56 but the more I search the forums, it seems that there a few people running 3 spd = 4.88. But I've been told that's too much for my trans??
Any thoughts on that? I also can't seem to find any hp D30 and if I buy the G2 fully assemblied axles ex. from 4wd or something for the front/back its about $2400 each...
Davecore555 is offline
post #18 of 34 Old 07-18-2010, 12:20 PM
2003X
With the auto trans, it seems the gear of choice is 4.56. For the manual 4.88s is the gear of choice.
I ordered my HPD30/8.8 for $2,100 shipped.
Can you post the link to the G2 axles? $2,400 IMO is a good deal if they are fully assembled. Because when I was doing my research, I couldn't find a G2 axle for under 4 grand a piece.
My Build
2003X is offline
post #19 of 34 Old 07-18-2010, 06:54 PM Thread Starter
Davecore555
post #20 of 34 Old 07-18-2010, 07:03 PM Thread Starter
Davecore555
Also if I were to order a Ford 8.8 & HP D35 from the eastcoastgearsupply.com site what options would you get and which would you not get.
I'm going to want the install to be as simple as possible; I will have a shop installing. Also if I were to swap my current stock D35c/D30 setup with the new Ford 8.8/HP D30 combo; what else will I need to buy??
Also what would be the max tire size you would run with these? I plane on only running 35's, but then I began to think my R.E. 3.5' lift is not high enough for 35 tires... Any opinion on that??
post #21 of 34 Old 07-18-2010, 07:41 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
HP D35
Huh?...
Knuckelhead is offline
post #22 of 34 Old 07-18-2010, 09:42 PM
ceasar_1
[QUOTE=2003X;9765082]I was running a setup D30/D35 with 3.07s and 35" Toyo MTs. I recently went to HPD30 and Ford 8.8 with 4.88s and couldn't be happier.
I personally wouldn't dump any money into the D35. I was going to do the same thing, and had the HPD30 and Ford 8.8 shipped to my house for 2 grand. Same price it was gonna cost me to re-gear the D30/D35.
Do it right the first time and get a stronger rear axle. You can get the 8.8 shipped to your house for around $1,500 and just bolt it in, if that's the route you want to take.
Where did you order an 8.8 delivered for $1500?
Never mind, found it, thanks.
'Two things are infinite: The Universe and Human Stupidity and I'm not sure about the universe.' Albert Einstein
ceasar_1 is offline
post #23 of 34 Old 07-18-2010, 09:54 PM
2003X
[quote=ceasar_1;9810464]
Drivetrain Specialists East Coast Gear Supply
My Build
2003X is offline
post #24 of 34 Old 07-20-2010, 06:49 PM Thread Starter
Davecore555
Sorry meant HP D30.. KnuckelHead.
Looks like the Ford 8.8 seems like a good option with the HP D30 too.
As mentioned above though. The additional options they offer I am not 100% on. How are their used shafts?
Any suggestions on which options are worth it and which aren't? Same for the HP D30.
Also what other upgrades are going to be required for the ford 8.8 conversion? Will I need anything like a SYE, CV shaft etc.
post #25 of 34 Old 07-20-2010, 09:47 PM
2003X
I got the used shaft option for the 8.8 and I am happy with it.
For the HPD30, I re-used my stock shafts from my LPD30.
You will need a sye/ds/adj uppers.
I am running it with stock ds and stock uppers, but need to get sye soon.
My Build
2003X is offline
post #26 of 34 Old 07-21-2010, 04:59 PM Thread Starter
Davecore555
Wow so on top of the cost of the HP D30 & Ford 8.8, I'm going to have to add a SYE, CV DS, and Adjustable Upper Control Arms??? Just to run 35's is getting $$$$.
I wonder how the uppers and all will affect my R.E. 3.5 lift??
post #27 of 34 Old 07-21-2010, 05:09 PM
freeskier93
Question 1: $1,750 for all 5 I guess is a good deal. I paid $1,200 just for the Toyos, and $500 for rims.
Question 2: Get stronger rear axle and go 4.88s. http://eastcoastgearsupply.com/ is where I ordered mine.
Question 3: Keep the TJ.
Really? I can get the 8.8 from them for 1225. But that's using used components and factory LSD.
freeskier93 is offline
post #28 of 34 Old 07-21-2010, 08:44 PM
2003X
I don't know what your trying to say? Depending on the options you want the price will fluctuate.
Right, 1225 + 250 to ship, so like I said, around $1,500.
My Build
2003X is offline
post #29 of 34 Old 07-21-2010, 08:54 PM
Jay12
35s aren't cheap to build for..
Jay12 is offline
post #30 of 34 Old 07-21-2010, 09:36 PM
freeskier93
Sorry I wasn't very clear. I was trying to say you could get it cheaper, but I didn't realize you were including shipping so it doesn't matter.
axles , gears , tire size
Axle or Gear Upgrade photoboy74 YJ Wrangler Technical Forum 7 05-12-2010 02:41 PM
axle/gear upgrade advice... gunnerharley TJ Wrangler Technical Forum 2 11-08-2009 10:46 PM
LJ axle upgrade and re-gear questions gcally TJ Wrangler Technical Forum 19 01-28-2009 06:02 PM
Axle/Gear Upgrade Options dpoelstra TJ Wrangler Technical Forum 14 08-11-2006 10:15 AM
More axle?s Upgrade D35 or swap it out? Jeep14636 TJ Wrangler Technical Forum 29 01-15-2005 09:12 AM
