Need Gear upgrade/Axle Swap Advice - JeepForum.com
post #1 of 34 Old 07-10-2010, 09:37 AM Thread Starter
Davecore555
Here we go...
Well I plan on getting a new jeep in about 1 to 2 years once the new penstar engine has ran for a bit in the jeeps. Not sure if I can hold out.
I had a buddy of mine who has put about 100 miles on a set of 35" Toyo Open Country M/T tires and **** Cepek DC-1 and said that he would sell me all 5 for $350 each. He wants 37s now. See pic attached.
Question 1: Do you think it is worth it????
If I go with 35s I was planning on upgrading to 4.88 Superior Gears. I currently have the factory axles for a 99: Front Dana 30 & Rear Dana 35c (3.73).
I found I could buy the superior 4.88 gears and master install kit for about $568. See pic, pretty sure this is all compatible.
Question 2: Do you think this is wise? Both mechanically & financially or would a axle swap with the 4.88 gears or even 4.56 be wiser??
And I have someone that has installed gears about 6 or 7 times before and never had issues who will do it for little $$$, plus hes a good friend who is a mechanic.
Please any constructive feedback would help out.
Question 3: Since I'm getting a new jeep in about a year or 2 do you think its wise to even do this?? I'm gonna have to buy new tires within the next few months anyway.
My setup>
99' Auto TJ Wranger:
3.5 R.E. Standard Lift
BDS 9500 Shocks 3"
Rancho Steering Stablizer
Teraflex Adjustable Track-Bar (3" & up)
K&N Air-filter
Pace-Setter Headers
33x12.50x15 Dayton Timberline A/T
Warn Front/Back Bumper
Dynomax Exhaust
High-Performance Catalytic Converter
tires 1.jpg   tires 2.jpg   tires 3.jpg   Superior Gears & Pinion Set and Install Kits - $568.61.jpg
Davecore555 is offline
post #2 of 34 Old 07-10-2010, 10:56 AM
2003X
I was running a setup D30/D35 with 3.07s and 35" Toyo MTs. I recently went to HPD30 and Ford 8.8 with 4.88s and couldn't be happier.
I personally wouldn't dump any money into the D35. I was going to do the same thing, and had the HPD30 and Ford 8.8 shipped to my house for 2 grand. Same price it was gonna cost me to re-gear the D30/D35.
Do it right the first time and get a stronger rear axle. You can get the 8.8 shipped to your house for around $1,500 and just bolt it in, if that's the route you want to take.
Question 1: $1,750 for all 5 I guess is a good deal. I paid $1,200 just for the Toyos, and $500 for rims.
Question 2: Get stronger rear axle and go 4.88s. http://eastcoastgearsupply.com/ is where I ordered mine.
Question 3: Keep the TJ.
My Build
2003X is offline
post #3 of 34 Old 07-10-2010, 10:59 AM
Jay12
Depending on what gears you have now you may need a new carrier for the D30 as well. And if you're getting a new jeep in 2 years and don't plan to offroad this then I wouldn't spend the money.
Jay12 is offline
post #4 of 34 Old 07-14-2010, 05:18 PM Thread Starter
Davecore555
Thanks for the feed back guys.
It seems regearing is a way to go; however alot of forums and sites say expect some breakage if you do any medicore offroading. So I'm thinking of just going for a bolt on axle(s).
1. Any suggestions; I really don't want to break the bank either
2. Do you think it will be ok running 35' tires on a jeep with a R.E 3.5' lift?
3. Planning on getting different fenders; was thinking bushwackers but read some pretty bad things about them; looking for something that will give me more room.
post #5 of 34 Old 07-14-2010, 05:33 PM
never monday
4.88 is too high for your trans
never monday is offline
post #6 of 34 Old 07-14-2010, 07:45 PM Thread Starter
Davecore555
So a 4.56 would work fine for the 35's? Probably will never go bigger as long as I have the TJ.
Also do you think it would be necessary to get rid of the front D30? I was thinkin of getting a D44 on the back and keepin the D30 or maybe getting a HP D30?
Any thoughts
post #7 of 34 Old 07-14-2010, 07:47 PM
Jay12
yep 3 spd auto and 35s=4.56s
Jay12 is offline
post #8 of 34 Old 07-15-2010, 05:25 PM Thread Starter
Davecore555
So it looks like the 4.56 gears are good then.
post #9 of 34 Old 07-15-2010, 05:29 PM
never monday
an HP30 and a Super35 or 44 is a proven combination fo0r 35's
post #10 of 34 Old 07-15-2010, 05:47 PM
LMoscar45
I wonder how much different the 3 speed is for gearing vs the 03 and up 4 speed? Most of the guys on another rubicon specific forum swear by running 5.13's when going to 35's.
LMoscar45 is offline
post #11 of 34 Old 07-15-2010, 05:50 PM
never monday
night and day. We've had many discussions about it, search.
post #12 of 34 Old 07-15-2010, 06:45 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Fill in your profile...
Knuckelhead is offline
post #13 of 34 Old 07-15-2010, 06:58 PM Thread Starter
Davecore555
Any suggestions on where to purchase the Dana 44 Rear and the HP30??? Really not trying to break the bank.
post #14 of 34 Old 07-16-2010, 03:36 AM
Coop02x
If your willing to be patient, try looking at a variety of forums, craigslist, etc. and you should come across what you are looking for. When I was facing the whole regearing issue, I kept an eye out for a rear and/or front D44 or an 8.8 that had the brackets already welded on. I ended up getting a rear D44 and front D30 with 4.88 gears at a really good deal. I would have liked to get a D44 for the front, but for the time being it wasn't a bad idea to get the D30. Came out much cheaper than just regearing the D35c and D30.
Try to find some local forums and be sure to keep a close eye on them. That is how I came across mine.
Edit: I was fortunate enough to find mine in about two weeks of serious looking.
Coop
Coop02x is offline
post #15 of 34 Old 07-18-2010, 12:08 PM Thread Starter
Davecore555
My buddy has a Ford 8.8 from his mustang and said he would sell it to me for $300. I woudl still need to regear however. Will this work, I've read some horror stories with the 8.8 swap.
Also would I need to get a sye, new drive shaft etc...
axles , gears , tire size
Axle or Gear Upgrade photoboy74 YJ Wrangler Technical Forum 7 05-12-2010 02:41 PM
axle/gear upgrade advice... gunnerharley TJ Wrangler Technical Forum 2 11-08-2009 10:46 PM
LJ axle upgrade and re-gear questions gcally TJ Wrangler Technical Forum 19 01-28-2009 06:02 PM
Axle/Gear Upgrade Options dpoelstra TJ Wrangler Technical Forum 14 08-11-2006 10:15 AM
More axle?s Upgrade D35 or swap it out? Jeep14636 TJ Wrangler Technical Forum 29 01-15-2005 09:12 AM
