Need full wiring schematic for 97 TJ - JeepForum.com
post #1 of 6 Old 03-31-2009, 09:13 PM Thread Starter
danheit
danheit's Avatar
1979 CJ7
Guys, I need some help. My other post on here tells the woes of my wacky instrument cluster, and the electrical gremlins that are ensuing. It is NOT the typical problems, and I need to get an idea of where all the wiring runs from between the ignition switch to the instrument panel. Anyone that can help, please do! I am looking for a diagram for a 97 TJ 2.5L 5spd. Thanks!
I NEED A SINGLE 15X8 MICKEY THOMPSON OR SIMILAR ALUMINUM BULLET HOLE WHEEL!!!!
Build Thread: 1979 CJ7
danheit is offline
post #2 of 6 Old 03-31-2009, 09:32 PM
George Dickel
George Dickel's Avatar
After a quick glance at the FSM, there are 8 pages of schematics alone for just the instrument cluster.
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
post #3 of 6 Old 04-01-2009, 03:01 AM
Line82
whats going on with the instrument cluster? if it's screwing up on you, i heard that it might be a good idea to just check the connections (there are 2) on the back of the cluster. make sure they are clean and no wires are pulled out. it's easy to get that cluster out.
1998 Jeep Wrangler Sahara
4.0L, 5 speed
Line82 is offline
post #4 of 6 Old 04-01-2009, 06:57 AM Thread Starter
danheit
danheit's Avatar
1979 CJ7
Thanks Line82, but I am WAAAAY ahead of that. Here is my thread on my problem.
danheit is offline
post #5 of 6 Old 04-01-2009, 07:06 AM
Zachs
You must be having the notorious, HOLY CRAP EVERYTHING DIED WHILE I'M DRIVING
2000 Sahara TJ
1997 Limited ZJ
Zachs is offline
post #6 of 6 Old 04-01-2009, 08:24 AM
sportcoupe
Here are the 1998 wire diagrams. It should be close enough to the '97.
www.blackgto.com/jeep/98wiring.pdf
sportcoupe is offline
TJ Dash Light Wiring Schematic? CJnaTJ TJ Wrangler Technical Forum 2 12-29-2008 12:28 PM
Wiring schematic needed docneon TJ Wrangler Technical Forum 0 08-30-2007 05:31 AM
OEM Fog Light Wiring Schematic Jeep_Maniac TJ Wrangler Technical Forum 4 10-01-2005 12:42 PM
yj wiring schematic..... blakkbelt YJ Wrangler Technical Forum 8 01-08-2005 05:22 AM
wiring schematic aboynamedmoose TJ Wrangler Technical Forum 1 11-22-2003 08:04 PM
