name that wheel.... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > name that wheel....
Jeep speedometer gears at rockridge4wdNitro Gear Packages Now Available at Rockridge 4wdFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 02-03-2014, 10:01 PM   #1
alabamaleo
name that wheel....
I have an 2004 Rubi, I am looking for a set of stock wheels. The door sticker says they were 16". What i need is the name that jeep called them so i can narrow the search.
Thanks
J
alabamaleo is offline   Reply With Quote
Unread 02-03-2014, 10:05 PM   #2
sjones26573
Au revoir, gopher.
sjones26573's Avatar
Moab
The Yellowtail Build
Originally Posted by Jeremy Clarkson - Top Gear Botswana Special
Why don't all cars have no doors? When I come to power I'm going to make it a rule because this is just better.
sjones26573 is offline   Reply With Quote
Unread 02-03-2014, 10:13 PM   #3
amiller
^^^^ Yep, Moab.
2005 Jeep TJ with some upgrades
amiller is offline   Reply With Quote
Unread 02-03-2014, 10:13 PM   #4
geroux
I have a set of five off my '04 Rubi... I think about 10K on them before I replaced them... a couple dings from rocks on the beads but not bad... want 'em?
geroux is offline   Reply With Quote
Unread 02-03-2014, 10:34 PM   #5
alabamaleo
Thanks for the quick replys guys. Geroux let me try to find them closer to home 1st. the shipping from Tx. woild prob put them out of my $$ range, I will let you know.
Unread 02-03-2014, 10:54 PM   #6
amiller
alabamaleo, there are also Moab wheels for the JK, but they will not work on the TJ without wheel adapters for the bolt pattern. the ones you are looking for have a 5x4.5" lug spacing. Also, I believe that they are 17" for the JK.
Unread 02-03-2014, 11:08 PM   #7
momoney
How much you want for yours Geroux?
momoney is offline   Reply With Quote
Unread 02-04-2014, 05:54 AM   #8
2jhanna
4th wheel down in wheels 2/2 link below for a picture and specs if interested.
http://www.jeepforum.com/forum/f9/st...1/#post4131908
jhanna
denton county, tx
2jhanna is online now   Reply With Quote
Unread 02-04-2014, 05:53 PM   #9
alabamaleo
thanks for the link reff specs
Unread 02-04-2014, 06:23 PM   #10
jjvw
Hipster Jeep
jjvw's Avatar
Before you commit to the 16" rims, you might want to get a good idea of the tire selection. A growing part of me wishes I had the more common 15" size. My understanding is the even your 17" rims are more common thanks in part to the JK running that size.
'03 Rubicon
jjvw is online now   Reply With Quote
Unread 02-04-2014, 10:04 PM   #11
geroux
Sent PM
