Name that suspension! 06 Jeep Rubicon Unlimited - JeepForum.com
post #1 of 6 Old 05-23-2010, 10:39 AM Thread Starter
smoghog4
I hope someone out there can help me. I recently purchased a 06 Used Rubicon Unlimited. It has what I believe to be a 4 inch coil lift with 2 inch spacers ( above the springs ). The upper arms are all adjustable, however the lower arms are solid with a slight bend in each. The shock are stamped explorer ( which led me to think this was a pro comp setup ) however pro comp does not sell this combination. I want to set up the suspension due to the fact It has a slight pull to the left, but cannot find instructions on how long the upper arms should be front and rear ( eye to eye ). Has anyone seen this setup before ( below are Links to pics ). I also included pics of the steering which I believe is a currie setup???, not sure on the adjustable track bar which bolts to the original mount. Any help someone can provide would be appreciated.
Please see links
http://i907.photobucket.com/albums/a.../leftfront.jpg
http://i907.photobucket.com/albums/a...4/leftrear.jpg
http://i907.photobucket.com/albums/a...4/steering.jpg
smoghog4 is offline
post #2 of 6 Old 05-23-2010, 10:46 AM
ChiefWoohaw
RE adj uppers and some longer maybe Rough Country lowers . . . beats me.
ChiefWoohaw is offline
post #3 of 6 Old 05-23-2010, 10:51 AM
Tinga
I'd second the rough country as well. The Lower control arms look the same as the ones that came in my 4" Series II except bushing color. Mine are black, but I heard they changed those out recently
Girls like STROKIN too!
http://www.jeepforum.com/forum/f153/1971-jeepster-commando-1380633/
Tinga is offline
post #4 of 6 Old 05-23-2010, 10:51 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X2, those look like RE uppers but the lowers are pretty generic looking to it's hard to say on them. You got lucky on the steering, that is indeed from Currie.
Getting
Jerry Bransford is offline
post #5 of 6 Old 05-23-2010, 11:00 AM
ChiefWoohaw
Find a guy called Mr.Blaine if you need info on the Currie Steering
Seems to be a sourced together lift and I'd imagine it'll do alright. The uppers will help with the Pinion angle and the lowers are longer with helps with the heights. What kind of trackbar is on both front and rear?
post #6 of 6 Old 05-23-2010, 11:38 AM Thread Starter
smoghog4
First of let me say thanks to all of you for your replies.
05-23-2010 03:51 PM
Attached are links to the front and rear track bars
Front ( is adjustable but mounts to the stock bracket not sure what Mfg)
http://i907.photobucket.com/albums/a...ttrackbar1.jpg
http://i907.photobucket.com/albums/a...ttrackbar2.jpg
Rear ( is not adjustable not sure if stock? )
http://i907.photobucket.com/albums/a...rtrackbar1.jpg
http://i907.photobucket.com/albums/a...rtrackbar2.jpg
In your Guys ( and Girls ) opinion what would you start with in length for the uppers in the front. ( The rear pinion angle looks good probably wont change anything in the rear )
smoghog4 is offline
currie , lift , rough country , rubicon express
Got a new jeep! (06 rubicon unlimited) jgorm Wrangler General Discussion 16 11-30-2009 09:46 AM
"06 Rubicon Unlimited Suspension advice massjeep TJ Wrangler Technical Forum 12 08-15-2009 12:00 PM
Would is a hemi rubicon unlimited worth to you to buy? 33s, long arm suspension? SomerJeep Wrangler General Discussion 16 06-12-2009 10:02 PM
Jeeb Rubicon or Jeep Rubicon Unlimited? Indefatigable TJ Wrangler Technical Forum 11 07-03-2005 05:49 AM
stock Rubicon suspension on a stock Unlimited? IneedaJEEP TJ Wrangler Technical Forum 3 03-21-2005 03:04 PM
