Name this Noise (video) - JeepForum.com
post #1 of 20 Old 02-14-2010, 01:22 PM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
Name this Noise (video) *UPDATE* Still noisy!
Went wheeling in the snow yesterday, didn't get into anything too deep water wise. Fired up the Jeep this AM so I could air up the tires and heard some squealing, it sounded like it was comeing from the distributor area... It didn't sound like it's a belt, was behind the water pump (or so it sounded)
Thoughts?
http://img535.imageshack.us/img535/3501/img03221.mp4
Here are a few pics if anyone is interested - Picasa Web Albums - wade.leishman - Twain Harte 2010
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is online now
post #2 of 20 Old 02-14-2010, 05:24 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Thoughts?
Seriously? Nobody has ever heard this before?
2017 WK2 Overland
post #3 of 20 Old 02-14-2010, 05:47 PM
Black01TJ
Black01TJ's Avatar
It sounds like some sort of bearing failure.......Maybe something small, like an idler, or it could be something worse.
Are there any other indicators? Like a rough and/or low idle, hesitation when you step on the gas? Does the sound grow with the RPM's?
Black Jeep Club Member #212
Atheist Jeep Club Member #4
Black01TJ is offline
post #4 of 20 Old 02-14-2010, 05:52 PM Thread Starter
SuperWade2
SuperWade2's Avatar
No other indicators at all... and it only does this until it warms up (and not every time it's cool) ... after about 5-10 mins, no sound...
2017 WK2 Overland
post #5 of 20 Old 02-14-2010, 05:59 PM
Black01TJ
Black01TJ's Avatar
Just off the top of my head, I would say that you managed to get some water and/or debris into a bearing unit somewhere.... i.e. your a/c compressor, alternator, or (somehow) in your distributor. I would do the "stick" method to locate the problem...... take a stick or broom handle (minus the broom bit) and hold one end to your ear and touch it to different parts of the motor. The sound should get louder the closer you get to it.
Be careful of moving parts!
post #6 of 20 Old 02-14-2010, 10:11 PM
Skyryder
X2 /\
Idler pulley, alt.
Skyryder
'97 Black TJ - 4 banger - 5 speed
Proud user of the "K.I.S.S." Principle.
Black Jeep Society #264
Skyryder is offline
post #7 of 20 Old 02-15-2010, 04:26 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Bump for anyone else that might have heard something similar... I moved a broomstick arround touching different stuff, and got no closer to finding what was making the noise (but I do get to go buy a new broom!)...
Randomly replacing stuff since I can't find the noise is going to get expensive!
2017 WK2 Overland
post #8 of 20 Old 02-15-2010, 04:36 PM
scarbogarage
For a quick check, take the belt off and crank it up. See if it still does it. If it still does you know its not something the belt is turning! If it not something the belt is turning I would look at the distributor.
scarbogarage is offline
post #9 of 20 Old 02-15-2010, 05:44 PM
The27Jeenyus
someone had this problem a while back, the tread was something about " laughing monkey under my hood" or something about a laughing monkey. ill try to find ti
Zach
Originally Posted by Willy36 View Post
icequeen's got something sticky in her hair from some dude named zach
The27Jeenyus is offline
post #10 of 20 Old 02-15-2010, 05:45 PM
The27Jeenyus
Found it http://www.jeepforum.com/forum/f9/wh...-angry-876488/
Zach
post #11 of 20 Old 02-15-2010, 08:32 PM
Slithering_Joe
Distributor bearing or bushing.
4.0L TJ
Slithering_Joe is offline
post #12 of 20 Old 02-15-2010, 09:07 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Originally Posted by The27Jeenyus View Post
Yah, that's sure what mine sounds like... I"m not sure if I have that same doohicky on mine....that thread was from a 06 and my 99 doesn't even have what they are talking about replacing... that's about where my Distributor is...
-W
2017 WK2 Overland
post #13 of 20 Old 02-15-2010, 09:46 PM
Red_
2016 KL Cherokee
Its the dizzy
Red_ is offline
post #14 of 20 Old 02-15-2010, 09:55 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Originally Posted by Red_ View Post
Its the dizzy
Do I get to replace the whole thing, OEM Replacement, or are there better aftermarket options?
2017 WK2 Overland
post #15 of 20 Old 02-15-2010, 10:16 PM
Red_
2016 KL Cherokee
Its the bearing on the dizzy shaft that's squeaking. Far as I know, its a non serviceable part. I've never heard of any aftermarket dizzy that is superior to stock, or even corrects the fact that crud gets down the shaft and it eats the bearing. So any new one would do the trick.
Red_ is offline
Loud Clutch Clunk Noise When Engaged/Disengaged Under Load (Video) 01TJfuntime TJ Wrangler Technical Forum 14 10-21-2010 11:59 PM
noise from piston rods (video) & advice on what to do... Matt Graham YJ Wrangler Technical Forum 6 04-04-2009 08:57 PM
clutch pedal making crackin noise *video* mike68 TJ Wrangler Technical Forum 17 10-01-2008 05:41 PM
motor noise? with video for sound RnEmOvr TJ Wrangler Technical Forum 20 11-03-2007 11:01 AM
Startup noise (apparently not the fan clutch...) with video! GringoLoco TJ Wrangler Technical Forum 12 04-08-2007 09:42 AM
