Mystery Vibration at 65 MPH - NEED HELP - JeepForum.com
post #1 of 6 Old 09-08-2013, 11:41 PM Thread Starter
SteveT77
OK Guys this is my last resort. I can't seem to figure this one out. Please Help.
Here are the stats on my rig:
2000 TJ
  • 5.3 V8 Swap with 4L60E
  • AEV Pintler 35" wheels with Spidertrax adapters / Falken AT tires
  • Stock Dana 30 up front
  • Ford 8.8 in Rear
  • Upgraded JE Reel Driveshafts front and rear
  • Super Short SYE
There are a bunch more mods but that the basics...
Problem:
I'm getting a moderate vibration at about 65MPH to 70 MPH on the highway. one large enough to be concerned with. From the frequency of the vibration I thought it was rotational it seems to come from either the center or the front of the rig but I can't really isolate the location. It doesn't escalate when you hit a bump and you can slow down to 50 MPH and it goes away.
What I've done:
I thought it was either a driveshaft or tires. I replaced both of my driveshafts and put brand new AT tires on with brand new wheels but no luck. I then went to steering did the whole move the wheel at 10 and 2 while someone checks the linkages... I replaced some of my stock steering components and nada. I checked for trackbar movement and it looked fine to me. I also checked Ball joints, unit bearings, all my control arm bushings.
I haven't been wheeling lately in the rig. It was perfectly fine and then all of a sudden out of the blue, the vibration appeared. So, I don't think it could be an axle.
I'm am at my end with this issue! Where do I go from here???
I know there are tons of threads and I have done everything I can think of....
Thanks for your advice!
SteveT77 is offline
post #2 of 6 Old 09-09-2013, 07:30 AM
tyvanwie
Are you sure your tires are perfectly balanced? How's your alignment?
tyvanwie is offline
post #3 of 6 Old 09-09-2013, 08:37 AM
biffgnar
biffgnar's Avatar
Have you driven it with each driveshaft removed individually to see if it goes away?
biffgnar is offline
post #4 of 6 Old 09-09-2013, 02:32 PM
Mud Machine
Jeep Addict
Mud Machine's Avatar
^^This
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, 35" Pittbulls, 5.13's, Revolution Axle Shafts, LS-III, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #5 of 6 Old 09-09-2013, 07:01 PM Thread Starter
SteveT77
Thanks for the feedback guys.
Yes, I have driven it with the each shaft removed to see if it changes... nada
I could check the alignment but haven't thus far. It doesn't seem bad.
the interesting note is that it was driving just fine. Then one day out of the blue I got the vibration. no "event" to trigger the vibration.
I'm almost wondering if it could be an axel....
SteveT77 is offline
post #6 of 6 Old 09-10-2013, 07:43 AM
jpin86
I have the same problem. I've taken the driveshafts out one at a time, bought new tires, changed u joints in the driveshafts and front axles, installed new steering stabilizer, checked all steering and suspension components, and it still vibrates. The only thing that helped a little was having the tires road force balance. I still have a vibration at about 65mph. It's been that way for 2 years and 50,000 miles. I hope you figure it out.
jpin86 is offline
tj , vibration
