Mystery Tire Rubbing Sound - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Mystery Tire Rubbing Sound
Engo winches available at www.rockridge4wd.com! Free shippBLACK FRIDAY SPECIALS!! You asked, we deliver!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 06-24-2014, 10:58 PM   #1
Luuca
Professional Novice
Luuca's Avatar
OK, so today, I went for it and changed the rear brakes - disk & pads, adjusted the drum parking brakes, lubed all my suspension joints and ball joints, found out my exhaust was loose at the flange and tightened them up.
Everything was good before except I knew the rear brakes were dead. Now, whenever I turn two full wheels to the right while moving (i.e. typical 90 degree street without a stop sign, even at low speeds, it sounds as if my driver's side front tire is rubbing. I have inspected the tires lock to lock and there's no way it could be the tires on the flares - even in a turn at speed I don't get that much body roll with stock sway bar and quick discos.
I thought it might be my exhaust rubbing now that it's tightened up and in a "new" position, but it's really loud and sounds exactly like a tire on a flare. It doesn't sound like metal on metal. I can feel it through the floorboards while wearing tennis shoes. It's loud.
I also noticed that when going straight into my driveway at less than 10 MPH I get the same tire rubbing sound when I hit the little bump in the transition.
Before I did the rear brakes, when I first stared it rolling in the mornings, I would hear the tell-tale "woont - wount - wount" of a warped rotor coming from the rear that would go away as I drove for a little bit. I don't hear that any more at a rolling start as before. The rear e-brake drum pads were worn out, so I clicked them out a little. I do not believe I over tightened them because the e-brake is still worthless and won't hold against Drive idle with the handle all the way up.
I'm at a loss. This is not a necessary daily driver, but I was hoping to drive it more now to see if fixing that flange leak helps my mpg. That, and like everyone else here, I love driving my Jeep.
Could it be the front drive shaft u-joint going bad? If so, why would a right turn while moving set it off in this way and not a left turn? Any other ideas?
91 YJ "Alice" 2.5L AX5 D30/35 -Busted Knuckles Yellow Jeep Club #91
05 LJ Rubicon "Ghost" 4" RE Lift 1" BL 33s
TJ FOR SALE
Luuca is offline   Reply With Quote Quick reply to this message
Unread 06-25-2014, 12:31 AM   #2
Luuca
Professional Novice
Luuca's Avatar
Think I got it figured out, going to check the front axle u-joints.
TJ FOR SALE
Unread 06-25-2014, 09:03 AM   #3
jeff_in_rc
Well the tire rubbing sound while turning could be the tires rubbing on the LCA, look at those to see any signs.
2004 Jeep Wrangler Rubicon
Member of the Gear Grinders 4WD Club
jeff_in_rc is offline   Reply With Quote Quick reply to this message
Unread 06-25-2014, 12:19 PM   #4
Luuca
Professional Novice
Luuca's Avatar
Thought about that. The issue is it's not even near full lock when I get the sound. In fact, as I turn further, the sound goes away. I also notice the sound whenever the front suspension absorbs a load - albeit very briefly.
I could slap some masking tape on the LCAs and produce the sound to see if there's any rub, but it just doesn't make sense that a normal turn - that never produced any rubbing sounds before - would start at such a light turn now.
TJ FOR SALE
Unread 06-26-2014, 05:23 PM   #5
Luuca
Professional Novice
Luuca's Avatar
Issues solved. When i tightened up my exhaust flange, it pulled the rear exhaust in towards the fuel tank skid. it rubs when I turn right . Bending that back tonight after work.
TJ FOR SALE
Unread 06-26-2014, 05:40 PM   #6
jeff_in_rc
Good to hear!
