My upper soft door frame just fell apart - JeepForum.com
post #1 of 6 Old 07-29-2005, 05:22 PM Thread Starter
JeepZJlover
The bottom piece of sheetmetal attaching the three bars together has rusted to pieces. I can figure out how to fix it but how do i get the upper door skin off without ruining it. Its a factory top by the way.
1993 Cherokee 4dr SE green, 4.0, Auto, HP30, 8.25, 3" lift 31" Goodyear Duratracs, Custom made front recovery bumper, Kenwood radio, 12" alpine type e subwoofer,alpine amplifier, Smittybilt xrc8 winch, tuff stuff portable winch receiver custom modified. 2002 Jeep Wrangler Sport 4.0, 5 speed, Dana 30 front, Dana 44 trac loc rear, Stock
JeepZJlover is offline
post #2 of 6 Old 07-30-2005, 01:03 AM
44 NSB
NSB Florida Jeep
44 NSB's Avatar
Soft Door Frames and Skins
My 97 TJ has the same problem. The drivers side frame bottom edge is 50% rusted away. I purchased a Best Top Sail Cloth replacement. The installation instructions advised to cut the seams to remove the frame. That tells me thats the only way to remove the frame. Check E-Bay for old frames/skins to replace your rusted frame. Good Luck
1997 Red TJ
5 speed w/ NP 231, Nth 4.5" lift, AntiRocks front and rear, skids (tummy tucker, front dif, oil pan, GenRite fuel tank skid, RockJock D-60 4.88, Flex-a-lite fan, Flow Cooler pump, Rhino lined tub, American Eagle Alloys, SS LTB's 34" x 10.5 w/Staun beadlocks, Tuffy console, MileMarker Hydra 12000
44 NSB is offline
post #3 of 6 Old 07-30-2005, 10:45 PM Thread Starter
JeepZJlover
I dont want to replace the whole frame when i can just as easily cut the rotted metal out and weld new in.
post #4 of 6 Old 07-30-2005, 11:37 PM
river rat
Forum porn star...I guess
river rat's Avatar
You can find replacement skins cheap on Ebay from where people buy new tops and have hard doors.
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline
post #5 of 6 Old 08-01-2005, 10:31 PM Thread Starter
JeepZJlover
Yeah but if you cut the threads couldnt it just be resewn. I cant get crap off ebay I'm not 18.
post #6 of 6 Old 08-01-2005, 10:38 PM
Stu Olson
Stu Olson's Avatar
Get a needle and thread and give it a try. Seems as though you really don't have much of a choice unless you want to weld with the skids in place.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
Soft Upper Door Cut gumby885 YJ Wrangler Technical Forum 0 10-23-2009 08:44 PM
Half Door Upper Frame Question spaceboy YJ Wrangler Technical Forum 3 07-23-2009 09:20 PM
Can not seal the gap from upper door and door frame moldham YJ Wrangler Technical Forum 3 10-22-2008 12:10 PM
Soft Window Upper Frame fits wrong and leaks... anali TJ Wrangler Technical Forum 2 09-12-2006 02:49 PM
How do you remove the upper door skins from the window frame? SteelBlueTJ TJ Wrangler Technical Forum 2 06-12-2005 09:43 AM
